4WD not engaging.
Old 11-20-2009, 08:32 PM
Jeremy11's Avatar
4WD not engaging.
Ok... Last week my 4WD was working fine. Took my truck out tonight and all of a sudden my dash 4WD light is not turning on and my 4WD itself is not engaging. When i put it into 4H shortly after you can hear a click in the dash. My 4L is working. But not in 4WD. Im going to check my gear oil tomorrow. Any other suggestions?
This is in a 1990 4Runner 3.0 V6 automatic with auto-locking hubs
Any Help is Appreciated!! THANKS!
Old 11-21-2009, 12:01 AM
drew303's Avatar
Check the vaccum lines at the front differential. Wouldnt surprise me if you had a vac leak. The auto-hub system ... doesnt actually have anything to do with the hubs as they're basically spooled.. Theirs a vaccum driven mechanism on the driver side of the differential that basically engages the axles.
Engage the 4wd and check around bet you find a leak
Old 11-21-2009, 12:03 AM
drew303's Avatar
Then start thinking about converting to manual hubs. Theres threads on here that detail how to do it. Warn hubs are cheap and will work just fine, hell i got Aisin and Warn sets just sitting here, bout ready to chuck em. It's a cheap and not so hard modification
Old 11-21-2009, 12:38 AM
annoyingrob's Avatar
Check that the 4wd shift linkage itself didn't actually come off. The A340H auto transmission (which you might have) uses an electric solenoid for low range, and a manual shift linkage rod for 4wd. Also, if the transmission fluid is low, or too cold, it may not shift into 4wd.
Old 11-21-2009, 08:47 AM
Jeremy11's Avatar
So how would i go about checking for the vacuum leak.
Where would i find this. Or what does it look like?
Old 11-21-2009, 08:52 AM
RobD's Avatar
http://www.off-road.com/trucks4x4/ar....jsp?id=399612
Old 11-21-2009, 10:12 AM
jrobertson4runnner's Avatar
would you be willing to sell one of those sets of hubs? if so i might be interested.
Old 11-21-2009, 10:13 AM
Jeremy11's Avatar
i cheked my vacuum lines atthe top and there was no vacuum. i checked the lines at my front differential and there was no vacuum either. is there some sort of hose diagram where the hoses should go on the passenger side of the TB that are numbered 1-6.
Old 11-24-2009, 11:50 AM
NO Money's Avatar
drew303
hey drew befor you throw the hubs away any chance of you mailing them to me.. i need a set for a 94 ifs 4runner... hook a 4runner up!!!!!!!!!!!
Old 11-27-2009, 08:38 PM
Look underneath the truck, from what I can remember, there's a little metal rod that goes from the shifter, back to a little pivot, then forward to the side of the transmission.
Old 11-27-2009, 09:03 PM
2DoorRunner's Avatar
Im pretty sure i have the same problem. Either that, or im just paranoid.
Old 11-28-2009, 09:21 AM
Jeremy11's Avatar
I followed this diagram for my ADD vacuum lines and it fixed everything.
Except i dont know where the hose goes for the first insert in the first cluster of 3 at the top.
Old 04-15-2020, 07:18 PM
Logan R. Daugherty's Avatar
Hate to wake this up.
I know this thread is old, but i have an automatic 1993 4runner 4wd and my 4wd either seems weak or is not engaging..i have a small leak coming from tcase but only shows itself when i engaged 4wd. Any ideas? Im at a loss and just think i need a new tcase.
Old 04-15-2020, 07:38 PM
scope103's Avatar
Originally Posted by Logan R. Daugherty
... Any ideas? ...
Oh, I dunno, you could start by reading how the original poster fixed his problem. At least check those items.
... think i need a new tcase.
Why?
Old 04-15-2020, 07:43 PM
Why?
im thinking t case because the front drive shaft still locks in but wont pull me up a hill
kawazx636
10-06-2021 03:03 PM
Daenerysdad
10-01-2015 07:33 PM
tylermx71
09-29-2015 08:49 PM
Cycles
09-29-2015 06:37 AM
May-39
09-06-2015 01:05 PM
Quick Reply: 4WD not engaging.
