4Runner Roof Leaks!
Old 01-22-2010, 06:20 PM
azredliner's Avatar
4Runner Roof Leaks!
I have a 1987 Toyota 4Runner I bought over the summer and now I found that the top leaks. I moved the top back and cleaned the gasket and the lip where the gasket goes and it isn't leaking as bad, but when I took it through a car wash it was like someone turned on a faucet. Is there something else that goes above the rubber seal? Everyone so far has told me that it only has one piece of rubber.
I have some heavy duty 3M reflective tape that is 4 inches wide, I am thinking of laying a strip across the roof-to-cab. It's black (same color as my 4Runner), but reflects white at night.
I don't plan on removing the top anytime soon.
Old 02-11-2010, 11:39 AM
azredliner's Avatar
Fiberglass Top Leaking!
Hey man,
I posted this issue a few weeks ago and I never got an answer from anyone. Doesn't anyone work on their own rigs anymore?
My deal is, I bought my first 4Runner (I have Toyota pickups, just not a 4Runner) at the end of this past summer. It's been raining like hell here in Yuma, AZ and I have a leaking issue with the top.
It has the rubber gasket that goes between the cab and the top, but the water is coming in from the holes above the mounting bolts that go to the cab.
Can anyone tell me if their 4Runner does the same, and can anyone give me an idea how to fix it?
I was thinking of putting some silicon in the holes, or stuffing some ear plugs into the holes.
Old 02-11-2010, 11:45 AM
waskillywabbit's Avatar
Merged the two.
a thread please don't start another.
Just leaks around the cab to top 4 holes? Anywhere else? I've had half a dozen and never an ounce of a leak. Sounds like a bad seal on the cab, the top or both.
Old 02-11-2010, 11:53 AM
InternetRoadkill's Avatar
Replace the seal. It's about $40 from the dealer.
Old 02-11-2010, 11:59 AM
azredliner's Avatar
Thanks for merging.
Isn't this the seal?
The water is coming from the hole above the seal.
Is there just one seal, or is there more?
Old 02-11-2010, 12:06 PM
4Crawler's Avatar
That looks like the inner trim piece, there typically is a rubber seal glued to the cab and the shell presses up against that before the bolts are put in. That seal may be missing or has slipped out of position.
Old 02-11-2010, 12:46 PM
azredliner's Avatar
This piece is attached to a pinch seam. I pulled the top back and took it off and cleaned it out real good and put it back. That was the only rubber that was there.
I suspected something was missing because the holes lead straight up and out the gap between the top and the cab.
Is this the seal (mentioned by "InternetRoadkill") sold at the dealer for $40.00?
Old 02-11-2010, 12:51 PM
That gray thing is the interior trim. The weather seal is black.
Old 02-11-2010, 02:06 PM
azredliner's Avatar
I just called the Toyota dealer and they quoted me $27.00 for the rubber seal. They have to order it from Los Angeles, and it will be here in a couple days.
Thanks to all of you for your help.
Old 02-11-2010, 02:48 PM
blue_CA_yota's Avatar
Can you tell me the part number? I have a similar leak (not as bad though) but the guys who work at the stealership near me are all a bunch of A-hats and can't get anything right..
Old 02-11-2010, 03:16 PM
They are easy to install. It comes with a self-adhesive strip. You just need to center it. Start from the middle and work towards the ends.
Old 02-11-2010, 03:57 PM
4runnerx3's Avatar
Did you follow the tightening sequence in the owners manual?
Old 02-11-2010, 04:50 PM
azredliner's Avatar
Didn't know there was one.
I started with the top-to-cab bolts, then did the sides.
Also, just returned from the Toyota dealer, and he said there is only one seal shown in the parts manual (65888). (Here's a copy of the image from the manual.)
Old 02-11-2010, 05:47 PM
tj884Rdlx's Avatar
sorry man, i haven't been around since you posted, but it looks like you got all your answers already. as illustrated, the cap has one black rubber seal on it that keeps the weather out. if your cap doesn't have it, you need it. there is also a specific sequence to putting the bolts in. you put a couple in, put another pair in, remove the first pair, put in the rest, than retighten the first pair. it sounds absurd, but i figure it must be for a reason to be so specific. it's in the owner's manual but you can probably google search '4runner cap sequence' or similar.
if you bought the gasket from the stealer already, so be it. but if not, any waterproof, closed cell foam or rubber self adhesive gasket strip will work that's about 1/2" thick. wipe the surface with denatured alcohol first then press it on.
check the fiberglass top for punctures as well. my roof leaks cuz it's got a crack in it. some jackarse poked their finger in it while asking me "does this leak?" and i said "it probably does now" i'll reglass it someday.
Old 02-11-2010, 11:31 PM
azredliner's Avatar
Originally Posted by tj884Rdlx
...any waterproof, closed cell foam or rubber self adhesive gasket strip will work that's about 1/2" thick.
Where's a good place to find this strip?
Old 02-12-2010, 05:57 AM
4Crawler's Avatar
Installation procedure:
- http://www.4crawler.com/4x4/4R_TechI...opInstallation
Probably find something that would work at a good hardware store, look in the weatherstrip section. Or might try an RV or camper place for a cab-shell seal strip.
Old 02-12-2010, 07:51 AM
Toyotero's Avatar
Ditto on the bolt sequence. ¡Es muy importante!
That's good to hear that a new seal is still available for the 4R top. Toyota seems to keep seals available for a LONG time. A couple of years ago, I bought some new door and window seals for my Celica from the dealer in CA and it's 33 yrs old!
- Toyotero
Old 02-12-2010, 01:18 PM
azredliner's Avatar
IProbably find something that would work at a good hardware store...
AutoZone sells some for $15.00. I got some this morning.
Old 02-12-2010, 01:22 PM
4runnerx3's Avatar
Old 05-22-2015, 09:31 AM
LVJPW's Avatar
So I know this thread is old, but this part has been discontinued as of 05-20-2015 when I tried to find it. Part number 65888-89102 . Please post if you have a workaround or a good brand of weatherstrip that works well.
icentropy
09-16-2020 02:47 PM
andrewtexas123
07-14-2015 04:29 AM
87blyota
07-10-2015 04:31 AM
Avenged
07-09-2015 07:55 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 4Runner Roof Leaks!
