4Runner 94' Weak Transmission?
Old 01-21-2012, 10:32 AM
4Toyota's Avatar
I recorded it, please have a look.
www.youtube.com/watch?v=eHa4gWHE1SY
Old 01-21-2012, 11:44 AM
McKenna's Avatar
But does it still rev that high when you cycle through your gears manually (Not in Drive) ? If not then it would be a shift solenoid.
Old 01-22-2012, 03:20 AM
4Toyota's Avatar
All the gears work except for "D"
I'm scrapping the 4Runner anyways at a lost. :/
Old 04-19-2015, 01:54 PM
Manuel Taylor's Avatar
I am having a similar problem. I have a 94 4runner. My problem started after I had replaced the radiator. As of now i have a leak in one of my transmission cooler lines ( in the process of replacing it). The truck shifted fine after it warmed up(not an issue).Now the truck will need to be red lined to move slightly. then it will shift fine afterwards. I have replaced the fluid and the filter(no metal shavings) also I have replaced all of the solenoids. I do have the same problem in 4LO. reverse works great. Any help with this issue will be greatly appreciated.
mskalmus
05-28-2017 07:51 AM
Poncho0206
07-10-2015 06:21 PM
shar
07-09-2015 12:38 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: 4Runner 94' Weak Transmission?
