3vze upper end knock
Old 10-15-2013, 07:21 PM
rainsucks's Avatar
I have a '93 4Runner with the 3.slow.
I have a knocking sound in the upper end. The knock is much louder than a tick, its definitely a knock. Sounds like its in the passengers side valve cover.
When the motor is first started, it knocks 2 or 3 times, then stops knocking.
There is no knock at idle. When I rev the engine, the knocks comes back, then is gone when I get close to full throttle.
I'm certain its not a rod bearing. I had a bad rod bearing and replaced them all. This is a different noise and a different location.
I have taken off the throttle body, upper intake plenum, and the valve cover. I don't see anything obvious. ( it kinda sounds like there was something rattling around in the valve cover, but i cant find anything in there ). I checked the resistance on the injectors and they are 13.5 ohms. Tomorrow I am going to measure the valve lash.
Any ideas what it could be? I'm debating on sending the injectors to witchunter and have them cleaned and tested. But i don't wanna spend the money if I don't have to.
Thanks,
Mike
Old 10-16-2013, 07:26 AM
Gevo's Avatar
I'm not sure how a bad injector would lead to knocking.
But as far as idea on your issue, I would say definitely check your valve clearences. although I believe valve noises wouldn't come and go.
My dad's 1999 chevy 350 van is having similar issue, hugely loud knocks for a couple second at startup, then it runs very well. Also, can't start without a little spray of starter fluid.. weird problem that I have to fix. I wonder if it's same type of problem as yours now.
Old 10-16-2013, 07:37 AM
wmayota's Avatar
Mine had a slight knock, but it turned out to be a pulley for the timing belt.
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
kirkrunner
07-27-2015 07:59 PM
KyleT
07-21-2015 07:54 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: 3vze upper end knock
