3vze mystery miss
Old 09-02-2011, 07:24 AM
BMcEL's Avatar
Originally Posted by danny eaton
can any tell me the best way to remove the upper bolt 2nd above slave pistion. im going crazzy.
This has been answered for you not only in your thread but many many times around the forum.
Old 09-06-2011, 11:25 AM
scott90's Avatar
Also forgot to mention long cold cranking time to the symptoms
Old 09-06-2011, 11:40 AM
BMcEL's Avatar
That's most likely the cold start injector and/or its time switch. Could also be the coolant temp sensor.
Old 09-06-2011, 11:44 AM
scott90's Avatar
Brand new coolant temp sensor..so I'm thinking the code 24 I get could be my problem,I heard I can use a 22re AFM on a v6 is that true?
Old 09-06-2011, 11:47 AM
  #25
BMcEL's Avatar
Have you tested your AFM to make sure that's the problem?
Old 09-06-2011, 11:50 AM
  #26
scott90's Avatar
I don't have a tester and I'm not very savy with electrical
Old 09-06-2011, 01:10 PM
  #27
TNRabbit's Avatar
You can't use VAFM from other engines.
Old 09-06-2011, 01:13 PM
  #28
scott90's Avatar
Ok I had just hears some rumors they were interchangeable
Old 09-06-2011, 01:18 PM
  #29
BMcEL's Avatar
There are a few (certain Cressida/Supra 7MGE I think) that work with minor adjustments but it is not something I'd recommend to someone with limited experience.
Old 09-06-2011, 02:14 PM
  #30
rustyf99's Avatar
VAFM is easy to check with a "VOM" (Volt Ohm Meter) - set it to ohms and check resistance with the two wires on the VOM connected to the two proper pins on the VAFM. The FSM shows it clearly.
Also that screw on the throttle body is the idle screw, it has an o-ring that gets baked ... and guess what ... causes a vacuum leak! You might want to check that, mine was causing me fits with idle, missing, etc. Fixed that and found a very minor vacuum leak on the brake booster hose this past weekend, now running like a top again.
Old 09-06-2011, 03:11 PM
  #31
scott90's Avatar
Pulled my cap and rotor and tightened the screws inside now it wont start
Old 09-08-2011, 05:49 PM
  #32
tropics's Avatar
Had a similiar problem, intermittent misfire and it ended up being the coil wire to the distributor had some corrosion and was making intermittent contact. Worth a try, free fix if it works. Good luck.
Jayboy74
10
12-21-2021 08:27 AM
JHalcyonM
03-06-2019 08:37 AM
Duppie007
08-31-2015 07:04 AM
skypilot
08-25-2015 01:09 PM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
Quick Reply: 3vze mystery miss
