3VZE Low Idle
Old 01-06-2012, 02:52 PM
adamthedroog's Avatar
3VZE Low Idle
Hi
My truck runs perfectly fine when I first start it and even sometimes after I've stopped it then started it again. (For example if I stop to go into the store). But sometimes after a while when I start it up again it revs up to about 1000 rpm then drops to about 500 rpm. After I've driven it for a while after that happens it goes back to around 850 rpm like it should.
Old 01-06-2012, 03:32 PM
rworegon's Avatar
Check all the vacuum hoses and intake tube for cracks/leaks. Vacuum leaks can cause the idle go weird.
Old 01-06-2012, 07:13 PM
TNRabbit's Avatar
Also check that your oil dipstick is securely inserted & the oil fill cap is tight.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 3VZE Low Idle
