3VZE loosing coolant
Old 12-08-2012, 10:19 PM
j2the-e's Avatar
Originally Posted by Chooch
And how can I for sure confirm its my headgaskets before I get into the job?
here you go
Originally Posted by BMcEL
Check for hydrocarbons in the coolant. You can get a test kit at most auto parts stores. .
Old 12-09-2012, 08:43 AM
ZUK
ZUK's Avatar
Well, just did a compression test. My motor has 250kms (155miles) and it came out great.
cyl 1 - 183psi
cyl 2 - 178psi
cyl 3 - 182psi
cyl 4 - 172psi
cyl 5 - 179psi
cyl 6 - 185psi
as you can see those are excellent numbers, I think ive determined its not my head gasket, what do you guys think?
Chooch----If I were to graph those 6 points then cylinder #4 would be out of the average range. Just a guess but I would like to bet that #4 has coolant going into it. If the plug is clean then that is the case.
If that is the case then next question is how is the water getting in there. HG is the obvious one.....also, a pinhole in the aluminum intake could cause it. I would think a pinhole would cause all 6 cylinders to be clean.
Old 12-09-2012, 12:50 PM
Chooch's Avatar
Finally found where the coolants going!!
Old 12-09-2012, 01:37 PM
j2the-e's Avatar
Time for a 2uz swap!
Old 12-09-2012, 04:12 PM
  #25
91_TOYOTA_4x4's Avatar
Yay fun! Whats your plan hg's or 3.4? I thought about a 3.4 when mine went but 3.4's seem to be hard to find in B.C. though i did see yesterday on B.C. 4x4 somebody selling a full 3.4 swap but i never looked into it so not sure what he actually has. Doing HG's isnt really that hard either. I think i got my hg's and gasket set for like 200 bucks or somthing? Then 6 cans of brake clean and many differnt oils later i had no leaks!
Old 12-12-2012, 09:10 PM
  #26
Chooch's Avatar
Doing the head gaskets. Got the heads off today, taking them to the machine shop tomorrow.
Blamalam
03-12-2022 07:34 AM
SubiKing
08-21-2021 03:57 AM
JaredL
03-28-2016 09:08 PM
izzmee
08-17-2015 10:20 AM
TJWilly
07-31-2015 02:05 PM
Quick Reply: 3VZE loosing coolant
