3vze lifter question
Old 12-25-2011, 02:20 PM
MudHippy's Avatar
If you say so...
However...we're not even done yet...
BECAUSE...
They truly are valve lifters, in the sense that they "lift" the valve, in exactly the same manner that a "traditional" lifter "lifts" the pushrod.
In reality though the term lifter is being misused in both cases.
A. You don't really "lift" a pushrod do you? No, you "push" it. You could just as easily say that the lifter "pushes" the pushrod which then "lifts" the rocker arm on one end(instead of vice versa). Think about it.
And..
B. When the valve is moved via the "valve lifter" on an OHC engine it's not being "lifted" either. It's also being "pushed", and in a downward direction. You can't lift something "downward", that's not possible.
See my point in all the clarity...pun intended.
Until I got here it was pretty much all misconceptions and gibberish....
Old 12-25-2011, 03:33 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Well, thank you for setting everyone and everything straight, Mudhippy. We'd probably all be strung out on crack or heroin having given up on any personal sense of mechanical knowledge were it not for your clarity of mind and technical excellence.
More eggnog, pleasthe.....
Old 12-25-2011, 03:49 PM
rworegon's Avatar
Originally Posted by thook
We'd probably all be strung out on crack or heroine
Me thinks heroine should be heroin.
Old 12-25-2011, 04:05 PM
thook's Avatar
Overly active fingers. Fixed, though......
Old 12-25-2011, 09:59 PM
  #25
Staff
DeathCougar's Avatar
So now its considered lifting when the valves are pushed down?
They are NOT valve LIFTERS.
Stop calling them lifters. OHC engines do NOT use LIFTERS.
Old 12-26-2011, 04:14 AM
  #26
thook's Avatar
I vote they should be called "push downers"! Kinda sounds like a hot, new, trendy, date drug.....
(Note to self: 1) Call Toyota CEO in the morning. 2) Throw a rave party tonight.)
Old 12-26-2011, 01:51 PM
  #27
truckmike26's Avatar
It makes sense since nothing is being lifted. But then the 1.8L pushrod flat four in my late grandma's '84 Subaru GL10 had valve sideways pushers. I'll go with "tappet" -- an any-position word.
Flossy
08-05-2015 05:14 PM
clok
08-01-2015 09:42 PM
91yotapup
07-27-2015 07:19 AM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: 3vze lifter question
