3vze Ground wire...where to connect
Old 05-14-2012, 12:24 PM
bomhour's Avatar
http://www.flickr.com/photos/42357420@N06/7198468254/
Can anyone tell where this is supposed to be attached? I think its a ground wire. It's for a 93 4runner driver side engine compartment and the other end of it runs to the inner fender wall below the coil/ignitor.
thanks for the help.
Old 05-14-2012, 01:38 PM
BMcEL's Avatar
Fixed the image. I'd have to look. Hopefully someone else will chime in sooner.
Old 05-14-2012, 02:05 PM
bomhour's Avatar
Thank you. I was under the impression that I could not post images because I'm too new.
Old 05-14-2012, 02:33 PM
wyoming9's Avatar
Red face
Any good ground on the engine should work.
although it does not hurt to clean the ring terminal and bolt.
Then I always put copper Never Seize on all the ground connections:jessica:
Old 05-14-2012, 03:00 PM
bomhour's Avatar
Thank you Wyoming9.
Old 05-14-2012, 04:29 PM
Team420's Avatar
that wire bolts on the block behind the alternator IIRC, I think I accessed it thru the wheel well.
Old 05-14-2012, 09:09 PM
bomhour's Avatar
Thank you. I will get that done tomorrow. Much appreciated.
Old 05-18-2012, 06:23 PM
ksti's Avatar
Mine is mounted on drivers side engine hook bolt
bvleonov
08-22-2015 11:39 PM
corey519
08-12-2015 11:12 AM
nonstop
7
08-11-2015 09:26 AM
Esibnitsud
07-30-2015 08:19 PM
v_man
07-23-2015 04:01 PM
Quick Reply: 3vze Ground wire...where to connect
