3vze Flame Thrower Injectors Review
Old 10-06-2017, 08:52 PM
  #41
ksti's Avatar
I would start your own thread and post up your test results.
You will probably get a better response.
Running rich doesn't tell much.
Old 10-09-2017, 08:32 AM
  #42
chefdave's Avatar
Originally Posted by shadowstewie
Hey guys! I pased smog in California in 2012. Decommissioned the 3vze for 2 years while replacing a ton of parts.
Flamethrower Fuel Injectors
Valve Cover Gaskets
Intake Manifold Gasket
PCV Valve
PCV Valve Hose
TVV Valve
Camshaft Seals
Crankshaft Seal
Spark Plugs
Idler Bearing
Tensioner Pulley
Hydraulic Tensioner
Water Pump
Thermostat
Upper Coolant Hose
Lower Coolant Hose
Radiator
Timing Belt
AC Belt
Power Steering Belt
Alternator Belt
Bilstein 5100 Series Shocks
Oil Pan Gasket
Oil Filter
Oil Drain Plug Seal
Inner Tie Rods
Outer Tie Rods
Swaybar Endlink Bushings
Upper Ball Joints
Lower Ball Joints
Driver Upper Control Arm
Pitman Arm
Both Axles
Brake Calipers
Brake Rotors
Brake Pads
Brake Lines
Cleaned Alternator
Cleaned Parts
Blue Vacuum Lines
Flushed Coolant, Toyota Red
I just tried to get it smogged after sitting for 2 years and replacing these parts little by little, and it failed smog in California. Guy didn't charge me but said it was running too rich. Any ideas? Do I need to pull the EFI fuse since I replaced the injectors? I read about changing the mixture with some turns and clicks? Can anyone give me an idea of what I can do. Thanks!
you need to get inside maf by removing plastic top which is silconed down. Inside is a cogged wheel and spring. Think you turn cogged wheel 2 clicks anti clockwise. There should be a write up on the tuning section under supra maf. Very simple to do once inside. Will see if i can dig out photo for direction of turning cogged wheel.
dave
Old 10-09-2017, 09:14 AM
  #43
scope103's Avatar
Start by scanning your report and posting it. "guy said ..." is a little too vague. Or, you can research it yourself here: http://www.cygnusx1.net/Media/Supra/...taTech/h55.pdf
".. changing the mixture with some turns and clicks" probably refers to hapless messing with the VAF. That won't help you at all in closed-loop, which is the only place you're tested.
You DO need to re-learn fuel trim, but you only need to drive it for 10 miles or so. You don't need to pull any fuses.
I assume, of course, that your CEL is working and you have no codes. If not, you SHOULD have failed for that alone.
Old 10-09-2017, 09:41 AM
  #44
ksti's Avatar
If the Toyota engineers wanted you to remove your "OEM VAF" lid they would have put fasteners on it, that's why its a sealed unit.
This might be the norm for a Supra MAF, mod, but the individual failed smog in "California". and I don't see where he did a Supra Mod.
As scope103 mentioned turns and clicks probably will result in more "hapless messing with the VAF"
He needs to start a new thread with his smog test results in order to have a starting point.
Old 10-15-2017, 07:23 PM
  #45
shadowstewie's Avatar
Hey guys, it turned out to just be the O2 sensor. Replaced it and it passed by a mile.
I wasn't sure if it had to do with the new Flamethrower Injectors and the 8% more fuel.
Appreciate all the help!
calderp
11-16-2015 02:49 AM
TOYOTASC
09-10-2015 05:18 PM
Boomer8404
09-10-2015 09:01 AM
EatChipsNow
09-09-2015 01:25 AM
Quick Reply: 3vze Flame Thrower Injectors Review
