3vze Distributorless Conversion
Old 09-13-2009, 09:24 AM
Brokedown's Avatar
Just curious if anyone has done a distributorless conversion on a 3vze?
Old 09-17-2009, 02:07 PM
MudHippy's Avatar
Well, Toyota did......sorta. Some later versions of the 3VZFE(which was little more than a 3VZE with twin-cam heads that they put in the 92-95 Camrys)came in a distributorless configuration. I'm no expert on that engine so don't quote me on that though.
It may be possible to fit that system directly, or with some modifications, to a 3VZE. I haven't heard of it being done, but would be very suprised if nobody else has thought about it.
Old 09-17-2009, 02:20 PM
Staff
DeathCougar's Avatar
There is no 3VZ ever made without a dizzy.
The 3VZFE was made from 92-93 for the Camry/ES300 and used a distributor. When Toyota redesigned the 3VZFE into the 1MZFE in 1994, they switched to non-distributor ignition, instead relying on cam and crank angle sensors.
The 3VZ has no provisions for a cam OR crank angle sensor, so it would be pretty difficult to make something like that work.
Old 09-18-2009, 11:37 AM
MudHippy's Avatar
Red face
Originally Posted by MudHippy
...I'm no expert on that engine so don't quote me on that though.
See, I was wrong....
Thanks DC!
Can't fault a guy for tryin' though...
MadMax48
03-03-2020 10:33 AM
live4soccer7
05-11-2016 06:52 PM
Kamaloha
10-16-2015 05:13 PM
alexcarey
10-14-2015 06:05 PM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: 3vze Distributorless Conversion
