3vze cold start injector advice
Old 11-04-2019, 07:42 PM
  #81
Austin Smith's Avatar
What cool did you replace
Please help
Originally Posted by ddv1126
Replaced the coil since then its been starting perfect. I guess the coil was working only sometimes. Thanks for the help Hans.
Old 11-05-2019, 05:04 AM
  #82
ddv1126's Avatar
Originally Posted by Austin Smith
Please help
I replaced the ignition coil
Old 03-24-2021, 07:51 AM
  #83
Jocas76's Avatar
Starts cold but not hot
Hello there. It's been a while and years have passed and now I'm dealing with a start issue.
Mine is a 91 M/T in tropical weather. The engine wouldn't start and the check engine indicator light is dimmed. If the green line that goes into the Cold Start Injector is jumped to ground, the check engine indicator light will recover brightness and the engine will start. The problem is once the engine warms up it won't fire back up...regardless.
My main question or concern is as to the reasons WHY the green line on the CSI has to be jumped and WHY the computer is experiencing a voltage issue as for an additional ground connection/jumper to be required in that particular cable/line in order for the engine to fire up. The issue reported by the guy in Puerto Rico mentions a similar problem but he never mentioned anything about a Check Engine light being involved.
Any ideas will be extremely appreciated. I'm just an enthusiast trying to save a dollar or two. TNXS
carlo082688
07-06-2012 12:46 AM
summit4runner
10-29-2011 04:57 PM
ls2camaross
01-13-2010 06:13 AM
ELD
01-07-2007 10:32 PM
grafix43
02-19-2004 07:27 PM
Quick Reply: 3vze cold start injector advice
