3VZE alternator pulley whine
Old 06-10-2012, 08:29 PM
70elcoss's Avatar
hey guys i have a little problem, sorta.... my alternator pulley seems to be making a whining noise. i rebuilt my completely 3.0 in January and since then it has been whining, at first i thought it was the belt because i reused the old one. i replaced the belt and it continued to whine so i sprayed the pulley on the grooves (where the belt makes contact) with some wd40 and it became silent!
so i know its the pulley.... what are my options for this? the alternator is the stocker but i replaced the brushes about a year ago so it works fine, just this noise is beginning to bug me lol
Old 06-11-2012, 01:44 AM
Toy3sgte's Avatar
Perhaps its not the pulley itself but the front alternator bearing. There is also a rear bearing.
http://www.lithiatoyotaparts.com/par...agramCallOut=3
I'm guessing supermarket bearings would be a fraction of the price. If that doesn't solve it I would check your headlight fluid reservoir
Old 06-11-2012, 06:53 AM
93toyrunner2's Avatar
If the noise stopped when you put WD40 on the pulley grooves, then the correct lubricant should be used - Belt Lube or Silicone Spray (Used on my truck for belts and window track rubber lubrication).
Old 06-11-2012, 10:06 AM
70elcoss's Avatar
I'm going to check out some silicon spray first, seems like the cheaper and easier way to go lol if that doesn't solve it then I'll replace the bearings, if it's the bearings can I just pack them with some grease and call it good or should i replace them?
Old 06-11-2012, 01:41 PM
Toy3sgte's Avatar
Silicon spray will probably stop the whining, but be aware that is not an actual fix. Belt dressing is just a bandaid masking an underlying problem. Ive never seen a Toyota manual recommend belt dressing.
My guess is since you replaced the brush, the bearings are old and wearing out. Whining has to come from vibration which can either be an out of wack pulley, mis alignment, or signs of failing bearings.
Who really knows though, the bearings may last another 5 years before they destroy themselves.
Old 06-11-2012, 01:45 PM
Toy3sgte's Avatar
Oh and those are sealed bearings. I don't recommend packing them with grease.
MadMax48
03-03-2020 10:33 AM
Kylenicoll33
09-17-2015 08:40 AM
LotOMiles
09-14-2015 11:45 PM
Corvoid
09-14-2015 10:10 AM
Quick Reply: 3VZE alternator pulley whine
