3VZE AFM adjustment
Old 02-08-2010, 02:34 PM
DupermanDave's Avatar
Works on the 22re as well. Definitely mark the area it was set to originally. Mine unwound and I haven't set it to stock yet. Performance is still good, mileage is still the same, but I'm paranoid it's affecting the vehicle's emissions.
Old 02-08-2010, 03:21 PM
Booosted Supra's Avatar
I just re-timed to about 17-18* I will fill up by the end of tonight on my usual 93 octane and we'll see what happens this week! Truck feels great
its 4 Clicks leaner, 17-18* degrees advanced, no EGR system with resistor in place, ISR mod, cat-back exhaust with high flow cat, brand new plugs and wires from Toyota, 93 Octane 187k on the clock
Old 02-08-2010, 04:04 PM
dfarr67's Avatar
I've got an extra afm to play with and I know what you guys are doing....but what's the ecm and O2 doing meanwhile?
Old 02-08-2010, 05:01 PM
Not sure but I don't have any codes of anything stored, I had three codes stored when I was doing my timing today but they were all for things I unplugged to get my VAFM off last night so I'll just have to reset tomorrow evening sometime
Old 02-08-2010, 10:00 PM
  #25
bottles's Avatar
what is a AFM?
Old 02-09-2010, 03:51 AM
  #26
Air Flow Meter
Old 02-09-2010, 03:59 AM
  #27
TNRabbit's Avatar
Originally Posted by bottles
what is a AFM?
Similar to a Mass Air Flow sensor, but different principle of operation.
Old 02-09-2010, 12:22 PM
  #28
bottles's Avatar
o ok well were is it at so i can play with it
Old 02-09-2010, 01:44 PM
  #29
MudHippy's Avatar
It sits directly atop the air filter box.
This thread, mentioned earlier, can tell you everything else you'll need to know.
http://www.customtacos.com/forum/showthread.php?t=56229
Make sure your careful not to get any moisture inside the AFM when you have the lid off. Be sure to seal it well when you put the lid back on when your through. Then you should be good to go.
Old 02-09-2010, 04:13 PM
  #30
dfarr67's Avatar
So for those who have run this adjustment for awhile.....is it permanent or will the ecm relearn back to stock?
Old 02-09-2010, 04:16 PM
  #31
az4x4runner's Avatar
You are physically adjusting the AFM, so I would imagine the only thing the ECM will learn is the new mixture.
Old 02-09-2010, 04:18 PM
  #32
dfarr67's Avatar
A little off topic- I recently recieved one of those 1982 Supra afm's and its sitting on the shelf until i can even plug it in and see if it works. Has anyone seen first hand what this mod will do to the fueling?
Old 02-09-2010, 04:24 PM
  #33
dfarr67's Avatar
So what I think I am hearing here...is the fuel trim is controlled by the afm- no, the afm is telling the computer how much air is coming in and you are fooling the ecm into thinking less air is coming so it's leaning out the mix- so this would be a consistant adjustment accross the board?
So the Toyota's are tuned rich, the narrowband O2 is doing it's thing around 14.7, I'm doing some programming on my 89 Chevy with TPI/map- this is so different.
Old 02-09-2010, 06:31 PM
  #34
bottles's Avatar
thanks
Old 02-09-2010, 06:49 PM
  #35
Thats about right, I can explain it a lot better but It would just confuse you I think, but yeah you get the idea, def go with a timing advancement too I'm roughly 17-18* on top of this mod testing a tank of gas right now for mileage, but remember higher octane! I'm on 93 octane
Old 02-11-2010, 03:47 PM
  #36
dfarr67's Avatar
Been driving my buddies 07 Tundra with a 5.7L while I was doing a timing chain- I guess my mileage isn't so bad after all- what a pig.
I run min 98 oct and will advance 2deg until ping then back off.
Old 02-22-2010, 01:25 PM
  #37
Brhesson's Avatar
Cool
Originally Posted by MudHippy
Yes, 3 clicks lean.
Tried 4 clicks, engine wouldn't idle smooth.
I HIGHLY recommend it. These engines are tuned way too rich from the factory.
I saw better mpgs and improved throttle response. Don't take my, or anybodies here, word for it though.
TRY IT!!!
ok, so i'm rebuilding the 3vze, remember me i was asking about head gaskets..so i've decided to just get the engnbldr.com 3.0 master kit & headbolts...should be here intime for a long weekend build up
and i have been thinking the intake looks pretty dicked up from factory...WTF...so i'm reading this ISR mod and changing the tuning etc...clicking something and speeding up the timing...how does one do these things, particularly when i am poor....due to this new project...lmao
looking forward to seeing this thing drive around like so
\....._____....^---... _____.../ **********
Old 02-23-2010, 05:06 PM
  #38
MudHippy's Avatar
It's more like you're recalibrating the system. The ECU doesn't actually change anything it does at all.
By tightening the spring that controls the amount of resistance against opening of the vane that the measures air flow through the AFM, you cause the opening/air inlet passage to be smaller/less open per given RPM. This doesn't richen the mixture by restricting the amount of air flow to the engine, as one might think, it actually leans it. This is because the amount of "restriction" to the intake air flow, caused by tightening the spring slightly, is small enough to be negligible(if it even exists at all, and could easily be adjusted out via the Idle Mixture Screw if it did). Closer to the truth is, it takes a given amount of air flow to achieve a given RPM, regardless of how "restricted" that air flow is. So, because the AFM is now telling the ECU it's allowing less air flow per given RPM(while it's actually allowing the same amount of air flow per given RPM), the ECU attempts to apply the correct amount of fuel to yield an acceptable air/fuel ratio by shortening injection times(allowing less fuel flow per given RPM). Thus, the engine will tend to run leaner.
About air/fuel tuning:
A well-tuned engine used in normal road conditions has an air/fuel ratio that is constantly varying. At light loads, lean air/fuel ratios are used, while when the engine is required to develop substantial power, richer (ie lower number) air/fuel ratios are used.
Bosch state that most spark ignition engines develop their maximum power at air/fuel ratios of 12.5:1 - 14:1, maximum fuel economy at 16.2:1 - 17.6:1, and good load transitions from about 11:1 - 12.5:1. However, in practical applications, engine air/fuel ratios at maximum power are often richer than the quoted 12.5:1, especially in forced induction engines where the excess fuel is used to cool combustion and so prevent detonation.
http://autospeed.com/cms/A_1595/article.html
Old 02-27-2010, 04:20 PM
  #39
airkewld4life's Avatar
So, today I decided to take the top off of an extra (bad) AFM I had lying around and tried to adjust the gear but to no avail it wouldn't turn. I depressed the little spring thing that jams the teeth but still could not get the cog to turn. Am I doing something wrong or is there some trick to turn that sucker?
Old 02-27-2010, 05:40 PM
  #40
Tracey98277's Avatar
what is a AFM?
Quick Reply: 3VZE AFM adjustment
