3VZE to 22RE swap
Old 12-16-2007, 03:32 PM
Cyberman's Avatar
3VZE to 22RE swap
I've searched, but want to verify this. From what I've read, it is not possible to bolt on a 22RE to a 3VZE manual transmission, and it won't bolt on to the existing motor mounts.
Can someone please clarify this? I have the opportunity to get a 22RE, complete with the wiring harness and ECU.
My 4x4 Extra cab originally came with a 3VZE and a manual tranny.
Old 12-16-2007, 03:37 PM
rdlsz24's Avatar
My truck has that swap, but I don't know a whole lot of what went into it since I bought it the way it is. I do see he had to weld the 22RE motor mounts onto the 3.0 motor mounts. I can take pictures if you want. Not sure if the 3.0 tranny works with the 22RE or not.
Rob
Old 12-16-2007, 04:27 PM
fillsrunner4's Avatar
You can buy a r151f tranny bellhousing to mate the two but your stock r150f bellhousing will not bolt up. Give marlin a call maybe he could sell you one. As for mounts youll need to make your own because it is true they are different. Also i hope you know how to wire because youll need to redue the engine to body harness in order to make it work
Old 12-16-2007, 04:31 PM
Cyberman's Avatar
Rob
Pics will help. I can't believe that the mounts that are on the frame are different.
I can wire, but you're talking about the wiring inside the cab, and not the ECU to engine wiring?
Old 12-16-2007, 04:36 PM
To mate the engine potion that goes to the dash. I believe its two plugs in the cab.
Old 12-16-2007, 05:16 PM
rdlsz24's Avatar
Here's 2 pictures I took of the driver side mount from different angles. The pics aren't the greatest since it's kinda hard to get in by them to get a good shot.
View from driver's front wheel well:
View from underneath front of truck:
As you can see the 22RE mounts are a couple inches more towards the front of the truck than the V6 mounts.
Rob
Old 12-16-2007, 05:22 PM
Cyberman's Avatar
That's weird. So, the motor is forward a few inches. I'll have to look at my friend's 94 22RE and see how that one looks.
Old 12-16-2007, 08:13 PM
Jay351's Avatar
woah, hackjob alert!
Old 12-16-2007, 09:12 PM
slater442w30's Avatar
Motor mounts are very different, if you dont believe, then go ahead and drop a new engine in there so I can laugh at you. Radiator is different, shroud is different, power steering lines are different, ac lines are different, tranny is different, fuel lines are all different, have a good time with that, I rip out 4 cylinders and put in V6's, done three so far, never been happier with a rig since the 22re was out of them, more power, more reliable, easier for me to work on but then again I am a mechanic.
Old 12-16-2007, 09:18 PM
yotasavg's Avatar
that's what i was thinkin'!!
Old 12-16-2007, 09:29 PM
CoedNaked's Avatar
Might as well put a 20R in there.
Old 12-16-2007, 09:32 PM
Ide say those mounts need some more to them
Old 12-16-2007, 09:52 PM
b.miller123's Avatar
if your truck is still running, then why even bother?
it's going to be more work than it's worth, and it will ruin your resale value, because nobody likes to end up with...............um........a hack job swap
how many miles are on the 22-RE? Do you know for certain that there is nothing wrong with it? ever heard it run?
I ask these questions because sometimes "a good deal" mearly means that it's not worth anything unless the guy selling it can convince you it is
If it really is a good deal, and you know what you are getting, then go ahead an buy it, and then find a truck with a blown motor, one that actually came with that engine, and replace it, you'll wind up with two rigs and (hopefully) neither will be a hack job
the amount of money/time/frustration that you put into trying to get a 22-RE into your truck will never be repaid in the mileage/reliability gains, which are minimal at best
Old 12-16-2007, 10:02 PM
CoedNaked's Avatar
Sounds like too much of a PITA to me and too much hacking that needs to be done. The 3vze is a good motor. Get a rebuild kit & give 'er.
Old 12-17-2007, 03:51 AM
Cyberman's Avatar
Just verifying the issue. No, the V6 doesn't run (PO threw 2 rods).
Old 12-17-2007, 04:25 AM
ozziesironmanoffroad's Avatar
then buy another V6. if anything buy a 3.4. way too much work to swap out the harnesses and crap
*edit* what i meant was if you're gonna swap harnesses anyway, go with the 3.4. sry, not fully awake
Old 12-17-2007, 06:17 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
This is like what happened to me....kind of. A friend gave my wife her '92 4rnr. The motor (3.0) had been completely rebuilt. After 21k miles, a rod or bearing cap (not really sure what) gave out, but the top end was still great. So, I bought another "complete" rebuilt for less than what it would have cost to have the original motor re-rebuilt. 3k miles later, the "new" one burned a valve and the cams and journals were scored beyond repaired. The top end was just not done right. SOOOO......I took the original top end and put in it on the "new" bottom end and now have a good working motor. I still came out little less than I would have getting the original motor rebuilt.
Since you have a good top end already, find a complete bottom end or a complete motor with a bad top end and you're in business, eh?
Old 12-17-2007, 06:19 AM
infiltrator's Avatar
arent you going "back in time" lol swapping for the 22re? why?
22re vs 5vze whats better?
Old 05-02-2010, 01:54 PM
JAH ARMY's Avatar
i take a 22 over a 3v anyday
Old 05-02-2010, 03:11 PM
Jay351's Avatar
Thread bump failure!!
Quick Reply: 3VZE to 22RE swap
