3VZ Problems
OK....I tried to bypass the TVV and connect the vacuum lines.....the motor seems to idle faster....so I plugged both lines.....now the idle is back to normal....something else I discovered is that when I start it up....cold or otherwise....the rough idle I was experiencing is gone....I got some 5/32 tubing and was gonna try to fix the TVV....but I might just leave it bypassed.....on another note....I stopped the water leak at the "U" hose on the back of the motor....but I still have one in the front (passenger side)...that appears to be coming from around the bolts in the bracket the holds the A?C compressor on.....still scratching my head....
Might have more than just that one leak.
finally found more time to work on my truck.....the rough idle at start-up is back...it's not as bad as before...but it's back. I noticed when you first start it, there is a little black smoke out the tail pipe, and it smells rich. I asked a friend that works on toyotas, and he said it sounded like an injector was "leaking"....I am going to try and replace the injectors...My question is....would you buy the re-man injectors or get OEM????
theking11863
03-19-2016 09:36 PM
D.B.T. 87 4x4
07-20-2015 04:51 PM
