3VZ-E Oil dipstick installation
Old 01-23-2007, 09:08 AM
brjason's Avatar
Yes, I do actually have a question about this...
Does the oil dipstick guide just slide into place at the bottom of the block (or is that the oilpan?) without any kind of gasket or sealant, or am I missing something? If that's the way it's supposed to be, why doesn't oil leak out around the outside of it? It seems like such a loose connection...
Perhaps I just need to be edjumacated about engines 101 or something.
Old 01-23-2007, 09:47 AM
callmej75's Avatar
I replaced the o-ring seal on mine and put RTV around it.
Old 01-23-2007, 11:06 AM
brjason's Avatar
What o-ring seal? The FSM I have refers to one, but it calls it the "o-ring seal on the dipstick," as opposed to the dipstick guide. Is the o-ring you're talking about on the dipstick guide or on the dipstick itself? I was looking for that last night after reading that in the manual, but I couldn't tell where there's supposed to be an o-ring seal.
Jason
Old 01-23-2007, 11:09 AM
callmej75's Avatar
Jason
Look around at the bottom of the guide tube....there should be a circle embedded into the tube that holds an o-ring. Go to the auto parts store and get an o-ring to fit on that. Its where it goes into the engine.
Old 01-23-2007, 11:18 AM
brjason's Avatar
Ah, perfect... I'm sure that answers my question.
Thanks!
Jason
Old 01-23-2007, 11:24 AM
callmej75's Avatar
Thanks!
Jason
You bet!
Old 08-13-2020, 06:26 PM
Jon Toreau's Avatar
Can someone get me a video or good photos where the guide is located and how if feeds down... I pulled my motor and it just doesn’t make sense I can’t seem to get it to sit where it looks proper. Also where the bracket is attached to ... 3.0 3vze
Old 08-14-2020, 10:17 AM
Loop320's Avatar
Your alternator bracket has 3 bolts, the dipstick guide bolts through the lower hole of the alternator bracket. Then feed through the hole in the motor mount into the block.
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
adammtb
07-27-2015 11:57 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 3VZ-E Oil dipstick installation
