3vz-e CAM REMOVAL NOTICE!
Old 06-14-2018, 08:23 PM
hashdfw's Avatar
Same busted cam w/me... I found cams on eBay for under $50 w/shipping. I went with one from RockAuto for $75 because it had a lifetime warranty. Good luck if that chinese flea-bay one is no good, but they could be the same cam for all I know...
I put both cams back in the head and measure the lifter clearance. It's about 3-4 thousand's less on the new cam. I mic'd the lobs and they're right at 7 thousand's larger than the original, which is likely do to 250K miles of wear and the new one has some kind of coating on the lobes which I'm sure will quickly wear off.
Colington
03-08-2020 09:51 AM
okamikai
04-30-2018 10:19 PM
thefishguy77
07-30-2015 10:59 AM
yourrealdad
07-21-2015 11:13 AM
horunner1x
07-10-2015 06:33 AM
Quick Reply: 3vz-e CAM REMOVAL NOTICE!
