3rz power problems!!!
Old 04-03-2015, 02:31 PM
ColoradoFourRunner's Avatar
Hello everybody, I have a 1994 4runner which originally had the 22re motor. The previous owner swapped the 22 for the 3rz... It's still a 4 cylinder. Don't get me wrong, I love a good, reliable, simple engine but, where is the power? I would really appreciate any recommendations you guys got to boost the power a little bit!
Thanks,
ColoradoFourRunner
Old 04-03-2015, 03:01 PM
JasonYota's Avatar
Manual or automatic transmission?
Old 04-03-2015, 03:40 PM
It's a manual
Old 04-03-2015, 04:31 PM
Robert m's Avatar
If the engine is running good and its geared correctly, the easiest thing to do would be to go drive a 22re powered truck and you will probably find it a lot more appealing to drive again.
Old 04-03-2015, 04:36 PM
bswarm's Avatar
I think the difference is about 40hp, right?
Old 04-03-2015, 06:23 PM
JasonYota's Avatar
^^ This. If you think it's under powered now, drive a 22re, yours will be a rocket
Old 04-04-2015, 12:18 AM
Robert m's Avatar
22R-E 114hp at 4,800 RPM 140 lb·ft at 3,600 RPM
3RZ-FE 150hp at 4,800 RPM 177 lb·ft at 4000 RPM
Old 04-04-2015, 09:11 AM
Has anybody thrown a turbo on one if these?
Old 04-04-2015, 09:35 AM
bswarm's Avatar
Turbo kits http://www.lceperformance.com/Street...-p/1071017.htm
They have them for 22RE also.
Old 04-07-2015, 06:15 PM
stanprophet's Avatar
You might be having a problem. My 3RZ has plenty of power. Can easily break the 31's loose if I try. Can you gain speed in 5Th gear up a slight grade?
Old 04-07-2015, 06:17 PM
Yes, check out the Marlin Crawler board, they take boost quite well, and make some serious power. I have a KO4B dual scroll turbo sitting here for a later date.
Old 04-08-2015, 10:31 AM
AZkid's Avatar
My 3RZ scoots a heck of a lot better than my 22RE. I have a 2004 3RZ,W56,5:29s and 37's and I can actually pass cars now. Check out customtacos.com They are minitruck guys who turbo, supercharge, and eliminate all the crap on these motors...
06-01-2021 01:51 PM
Sleaker
08-26-2020 06:03 AM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
mlavery85
07-12-2015 10:33 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: 3rz power problems!!!
