33 mud terrains on a 2.4 to much?
with a more spread out ie wider tire you maybe able to float more but it can reduce your traction since the tire does not create as much friction with the ground. Really this is dependent on a number of variables and you are both right.........
IMHO a 10.50 is plenty wide for a yota
#25
i'll be the first to say...that i've gone EVERYWHERE my friends have with their full size pickups and 12.50 wide tires...in my '86 with 10.50wide tires..and even been places they haven't.
but it woulda been BETTER to have 12.50's.
#27
back on gears i have a 22r stock gears and 36" tsl and an aussie in the rear daily driver. it is a little slow on the road but it pulls way better than my buddys jeep same gears ratio and 33". but jeeps are junk anyway haha
#28
actually traction is a function of weight and surface area......
#29
I drive it enough and will take it on long road trips that the 33" / 5.29 combo would be too much gear for highway speeds. My compromise after wheeling this weekend (and wanting more gear reduction off-road) is that I ordered a 4.7 transfer case gear set to help off-road, but keep the streetability.
Mine took a 1" body lift to get proper clearance for the 33's though.
I also added a Detroit locker at the same time as the 4.88's in the rear and it makes a huge diffrence off-road.
I don't plan on running 35's so I'm good with 4.88, but you should consider what you want to do. If its more that 50-50 that you'll add 35's at a later date, then go with 5.29's.
#30
I just put 33" Cooper Discoverer stt Mud Terrains on my truck and i love them, but im trying to figure out if its to much strain on the truck itself. it has 250k on the body. 3,000 on the brand new motor, 2,000 on the brand new transmission, and 6,000 on the brand new gears in the front end and rear end.
I have a 4 inch suspension lift and im afraid that the extended driveshaft is going to snap lol
What yall think?
What yall think?
My buddy had a 2.4 pickup and had super swampers tsl 33's on it. Had torque cams and headers done to the truck. And a lift of course. Looked great but was breaking axles left and right b/c he was always dumping the clutch to get the truck sideways. LOL Those were the days!!!!!
But yeah they will work for normal driving conditions!!!
#31
not like it matters but i went from the stock tires to 31 10.5 to 33.12.5 still rolling on the stock 4.56 gears and auto with a 2.4L 22re with the 33's i seem to go places and grip better then i did with the high traction studded 235/75 i had when i got the truck. and i have no issues doing 70 on the highway ( although i dont like to run that fast in the yota)
#32
Well i decided to put 5.29's in, along with a new 5 speed manual transmission,
Possibly going to get some 35's in the near future. But we'll see haha
But as for 5.29's and 33 inch tires, What is my gas mileage and speed gonna do?
#33
you should still get 18 to 19 mpg, and your speedometer will be off about 5% faster than actual. I put 5.29s, Aussie locker and 33x10.50 and everything is great. Its my DD and I have no problem doing 70 to 75. Oh yeah and the 10.50's will still stuff in the rear no need to cut anything.
#36
I won't comment on any tires, because the widest I've run is 10.5", however this is an interesting read:
http://www.expeditionswest.com/resea...tion_rev1.html
Toys4parts
09-26-2015 01:56 PM
