3.4 swaps galore. pics of 3 swapped trucks and more.
#81
Having a 3.4 swap done right now and ran into one issue...no were to connect S4 wire / 4th gera.
Vehicle is an 89 pickup auto 4x4 with 3.0
Donor was 2002 tundra 3.4 2wd auto
ORS says that you want to use a T100 ECU to avoid issue, so that is what we did.
The mechanic did all the wiring, no ORS harness at all.
All wires are connected and everything works except 2 things...below is the message from the mechanic.
"Your model year happens to be a hydraulic controlled t-case, so those two last wires (S4 & ECT PWR) directly connects into the ECU…S4 & PWR for ect is not present on t-100’s ECU so i’m stumped!"
“Notice the schematics shown for the 02 tundra and 96 t-100..
pwr (for ECT) and s4 connections are not present on both ECU’s”
So it drives and shifts fine, but wont go into 4th gear/ OD. AND...I guess the ECT things doesn't work...dont really care about that though.
Any advice...how to get an auto transmission to shift into 4th gear?
1st one completed over a year ago. about 45k miles put on the 3.4 motor since the swap was completed.
(my cousin's)
1990 Toyota 4runner V6 4WD Auto
-3.4 motor from a 99 4runner
-using original stock 3.0 tranny and t-case (we rebuilt tranny, t-case, internal mods, valve body mod to handle the
3.4 power)
-TRD supercharger with 14psi pulley.
-tach works
-auto speed sensor works
-no CEL
smaller pulley
3.4 cruise control
working tach
jdm hilux spoiler
2nd one, about 1 year since swap. (friend's truck, about to do another swap for him into a 95 4runner
limited 4wd auto for his wife)
1993 Toyota Truck V6 4WD Manual
-3.4 motor from a 99 tacoma
-stock 5spd tranny
-TRD supercharger with 12psi pulley.
-tach works
-no CEL
recently we relocated the battery to the driver side, and installed the stock 3.4 airbox.
3rd one (mine), recently finished
3.4 power)
-TRD supercharger with stock pulley.
-tach works
-no CEL
some random pics of our trucks.
our friend Todd's toyota truck.
toyota trucks and other cars at the my shop
towing the drift car, is300 turbo.
3.0 tranny and t-case rebuilding pics
EDIT: picture link fixed.
(my cousin's)
3.4 power)
-tach works
-no CEL
smaller pulley
3.4 cruise control
working tach
jdm hilux spoiler
-stock 5spd tranny
-tach works
-no CEL
3.4 power)
-tach works
-no CEL
Last edited by Sundown; 11-12-2022 at 04:18 PM. Reason: Text is missing...only photos showed up.
The following users liked this post:
Matthew_ (03-31-2023)
#82
#84
Texas_Ace
249
04-19-2012 06:05 PM
30, 32x1150x15, 34, 97, conversion, cost, fit, grille, headers, swap, tachometer, tacoma, total, toyota, trd
