2wd factory tire size
Old 03-21-2006, 05:18 PM
TinyTruck's Avatar
What is the factory tire size on a 94 2wd pickup
Old 03-21-2006, 07:06 PM
trythis's Avatar
have you looked inside your driver door B pillar, there should be a sticker that shows you.
Old 03-22-2006, 02:09 AM
TinyTruck's Avatar
been painted over
Old 03-22-2006, 03:23 AM
celica's Avatar
I believe they were the 225's
Old 03-22-2006, 04:40 AM
trythis's Avatar
My 4x4 is 225 75 15's, I think 2Wd would be smaller,my owners manual has the possibles listed and there are several mentioned. You could call a dealer?
Old 03-22-2006, 05:36 AM
nmtoy's Avatar
My 90 2wd came with 205-75-14 inch tires.
Robb
Old 03-22-2006, 05:53 AM
calg3's Avatar
Tire Rack would be happy to tell you:
http://www.tirerack.com/tires/Select...4&autoModClar=
195/75R14
Old 03-22-2006, 07:30 AM
curly_c's Avatar
this might be a thread jack so sorry. but what do all the numbers turn out to be. like 195/75r14 mean. i know the 14 is rim size? but what size does that turn out to be? my runner has 31x10.50x15 and i know what that means but the other numbers confuse me. sorry for the dumb question.
Old 03-22-2006, 07:53 AM
jethro's Avatar
http://www.tirerack.com/tires/tirete...currentpage=45
Old 03-09-2009, 06:24 PM
Daddio812's Avatar
I have a 94 standard, came with 195/75/14 .It is listed as such from the factory. The truck currently has 225/70/14 tires on it. So if your having trouble finding rims and the like , you have to look and talk to people that have a clue.
Old 03-09-2009, 07:34 PM
Tubbyfatty's Avatar
My 94 4runner came with 225s, my neighbors 94 4runner came with 31s, lol.
woops, both those 4runner arent 2wd, they are 4, haha.
Old 03-09-2009, 07:49 PM
xzyragon's Avatar
mines got 14" rims with around 24" tires...
but all 4 of my tires are different brands lol
Old 03-10-2009, 07:19 PM
Robert m's Avatar
why are people responding to a thread thats 3 years old and was already answered?
Old 02-16-2013, 07:41 PM
norse's Avatar
Because apparently other folks might be coming here with the same question. See? Here it is 3.5 years later, and I stumbled upon it looking for some info on what seems to be a scarcity of choices for tires for my '91 pu.
Old 02-16-2013, 09:26 PM
Co_94_PU's Avatar
Hope you found what you were looking for. For comparison I'm running the stock 195/75-14 in the front(for factory turn radius) and (+2's?) 215/70-14's in the rear(for extra traction). I had 205's in the front and they were rubbing the inner apron in tight corners, with factory setting on the turn stops.
Old 02-17-2013, 09:00 AM
norse's Avatar
Thanks very much. I'm becoming frustrated looking, as the only thing Firestone had was Primewells, and I'm not a fan of those. The only problem with running wider tires on the back is I won't be able to rotate. I'm still not sure on how all my four tires got cupped like they have. Firestone told me they're that way because they've not been rotated. But brakes look good, balljoints / bearings look good...
Old 02-17-2013, 09:49 AM
MudHippy's Avatar
91 4x2 Xtracab SR5 V6 205/75 R14
91 4x2 Xtracab Deluxe 205/75 R14
91 4x2 Long Bed Deluxe 195/75 R14
91 4x2 Standard Bed Deluxe 195/75 R14
91 4x2 Standard Bed 195/75 R14
94 4x2 Xtracab SR5 V6 205/75 R14
94 4x2 Xtracab Deluxe 205/75 R14
94 4x2 Standard Bed Deluxe 195/75 R14
94 4x2 Standard Bed 195/75 R14
Old 02-17-2013, 10:27 AM
Fordless's Avatar
Discount tire direct has 195/75R14 Kumhos for 80 a piece w/ free shipping. If I had to have an import tire that's probably the one I'd go with.
Old 02-17-2013, 09:43 PM
Co_94_PU's Avatar
Mudhippy: thank you sir! charts a like pictures, we love em.
Wider tires are fine generally speaking you'll only run into issues with really fat ones, like old school MT slicks. The ackerman compensation is based off the center of the axel, so you would only have issues with changing the offset spacing of the rims.
"won't be able to rotate" ?? Is this a race truck
By cupping you mean dished in the center? That would/could be from over inflation, or over speed on the tire rating, or maybe doing burnouts with hot tires. Overinflation could be a bad guage, but more likely just due to temperature changes. You can solve that by finding someone(good dealership) to refill the tires with nitrogen it is more temp stable, or adjust the tire pressure down after a long drive after the tires are hot.
Uneven tire wear, aka beveling, is due to not rotating. Not to knock your firestone rep but maybe he's new to the job.
Old 02-17-2013, 10:41 PM
Robert m's Avatar
so you searched, and found the answer you needed but decided to bump a now 7 year old thread to try and prove a point...?
he said cupping which is usually caused by a worn out damper,un balanced tire, or part of a bad alignment... not over inflation. i dont see how you would get the 2 even mixed up. but since you like charts.
Quick Reply: 2wd factory tire size
