2wd 1-ton Toyota Dually Axle
Old 08-07-2007, 06:38 PM
idayota's Avatar
Does anyone have any details about the 1-ton 2wd dually axles put underneath toyota dolphins, u-hauls and work trucks? I am curious to know more about it...is it an 8-inch ring gear? Will standard 8-inch gears fit? Is it a full floating axle? How wide is it? Any help would be much appreciated.
Old 08-07-2007, 07:02 PM
hmmwv15's Avatar
Here's a thread from a while back:
https://www.yotatech.com/forums/f5/9...pickup-107854/
Old 08-07-2007, 07:47 PM
tc
tc's Avatar
Definitely FF, and I think they used the 8" diff (instead of the 7.5" normally found in 2WD)
http://personal.utulsa.edu/~nathan-b...le/34reara.pdf
Old 08-07-2007, 10:36 PM
idayota's Avatar
that is a pretty cool pdf...but it still leaves some questions to be answered: anyone know the actual mounting surface to mounting surface width of the axle? can a standard 8-inch center section be traded into it? i would be very interested in answers to these two questions.
Old 08-11-2007, 04:27 PM
idayota's Avatar
bump. there's got to be a reason why no one builds these rear ends...why?
Old 08-11-2007, 04:32 PM
89silverpu's Avatar
perhaps because they're dullies...
Old 08-11-2007, 05:22 PM
ewong's Avatar
Big threads on this in Pirate4x4
First - off - they are not common
Second - its an 8 bolt lug nut pattern - so um - mis matched rims
Third - DRUM brakes
Yes - its a full floater
No one really uses this axle because the FROF kit does the same thing and its lighter and gives you rear disk brakes...
To get disk brakes on the Dually axle you basically do a FROF swap.
Then you need either
-- custome axles
-- LandCruiser axles
-- custom spacers
Its a ton of work to end up with an expensive version of the FROF kit....
Old 08-14-2007, 11:53 AM
idayota's Avatar
i thought they were 6 lug...
Old 08-14-2007, 03:17 PM
toy283's Avatar
They're six lug, but it's 6-on-8.5" instead of 6-on-5.5" so you'd still have a mismatch. Of course they are mismatched from the factory anyway (see above pic)...
Old 08-14-2007, 09:23 PM
idayota's Avatar
yeah, the front on those looks like a standard 2wd front 5-lug. just thinking.
Old 08-14-2007, 09:24 PM
idayota's Avatar
probably not worth the hassle...fzj-80 axles with rear discs would be the ticket i think. thanks for all your guys' input.
Old 02-28-2016, 08:25 PM
Okashiica's Avatar
1 ton dually axle replacement
I have a similar question I think. I just got a 1981 Toyota R22 Odyssey with a broken 1/2 ton rear axle. Doing some research, found out that the axles had been recalled for the mini RV's cause they weren't made to support the weight. They were apparently upgraded after '87 (for the 1/2 ton (standard on the Toyota pickups?)) but feel like the safest route would be to replace it with a 1 ton axle. Does anyone know compatible axles & differential for a Toyota R22 pickup? Or should I use 1 ton axles with the same differential? Or could I replace the axles/differential with a 1/2 ton pickup axle that I know will fit and relieve the weight enough by upgrading the leaf springs?
bigjstang
08-25-2021 12:41 AM
God's Bounty Hunter
07-08-2015 12:54 PM
ItsJustD
07-07-2015 07:49 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: 2wd 1-ton Toyota Dually Axle
