2nd Gen Toyota 4Runner Shifting Issues
Old 01-08-2013, 10:00 PM
DeathLK's Avatar
My Truck has rough shifting and I'm wondering what it is. I just changed the shift bushing and I bled my clutch and yet its still rough. It runs a bit better now but still doesn't work completely well. The clutch pedal goes down all the way before it actually engages(Sorta). Reverse grinds no matter what. I want to know what problems it could be and how I could fix it. Thanks
Old 01-09-2013, 12:15 AM
combatcarl's Avatar
Reverse is gonna grind. Non-synchro. Wait for a two count before stabbing backwards. Some guys report that finding a GL4 spec lube ( not GL4/5) helps with shiftering issues. I need to try it, unless I shift with little or no clutch (cold) I get resistance in all forward gears.
Old 01-14-2013, 05:11 PM
Co_94_PU's Avatar
Check for fatigue in the pedal mount. Adjust the linkage per the manual.
From memory the grinding should stop somewhere around an inch or inch and a half from the floor, when it's properly adjusted.
vasinvictor
01-20-2016 12:39 PM
JaredL
06-16-2015 04:47 PM
westbound
06-07-2002 03:30 PM
Quick Reply: 2nd Gen Toyota 4Runner Shifting Issues
