[22RTE-Trucks] automatic transmission A340 H ?????
Old 11-09-2006, 02:14 AM
swerks's Avatar
I thought the turbo 4runners with automatics had A340f transmissions.
the plate on my 86 4runner sayes H ??? will a 22re bolt up to a turbo
transmission??
Old 11-09-2006, 08:30 AM
Bill's Avatar
you need to keep the stock "converter" bellhousing.
The 22RTE has a standard 4cyl bolt pattern, and the A340F (or A340H) have V6 bolt patterns.
Old 11-09-2006, 09:23 AM
rezrunner92's Avatar
This is the information I have, this won't tell you about the bolt pattern etc. Just the trans designation. It is common for transmissions to have different bolt patterns for different engines while having the same designation number.
03-04 w/V8 4.7L RWD 5 A750E
03-04 w/V8 4.7L 4WD 5 A750F
95-04 w/L4 2.7L V6 3.0L 3.4L 4.0L 4WD 4 A340F
89-04 w/L4 2.4L V6 3.0L 3.4L 4.0L RWD 4 A340E
90-94 w/V6 3.0L 4WD 4 A340H
89-91 w/L4 2.4L RWD 4 A44D
85-89 All 4WD 4 A340E,H
*EDIT*
this info is 4Runner only
Old 11-09-2006, 09:24 AM
Pickups
68-74 HiLux RWD 3 A30
95-04 TACOMA w/L4 2.7L V6 3.4L 4WD 4 A340F
89-04 TACOMA w/L4 2.7LV6 3.0/3.4L RWD 4 A340E
85-04 TACOMA w/L4 2.4L RWD 4 A43D
93-98 T100 w/L4 2.7L V6 3.0/3.4L 4WD 4 A340F
93-98 T100 w/L4 2.7L V6 3.0/3.4L RWD 4 A340E
90-94 w/L4 2.4L 4WD 4 A340F
85-89 All 4x4 pickups 4WD 4 A340E, F, H
82-92 2x4 pickups w/ 4 cylinder RWD 4 A43D
75-81 2x4 pickups w/ 4 cylinder RWD 3 A40, A43
4x4-runner
12-27-2016 01:58 PM
BeMiceElf
10-10-2015 09:40 PM
eggens
09-05-2015 12:16 AM
kelly1450
09-02-2015 12:29 PM
Hugh_Mann
08-31-2015 04:02 AM
Quick Reply: [22RTE-Trucks] automatic transmission A340 H ?????
