22rte help!!!!!
22rte help!!!!!
ok so trying to find this electrical issue is like pulling teeth. i am getting no fire at all but the pick up coil, coil, distributor, ignition control mod, distributor cap, and wires all check out. most of witch I've replaced and the truck still isn't getting fire. I'm at a loss with this truck. is there any thing I'm missing?
"hit"... you mean "hot"?
I asked about the coil, but nevermind. So what module? The igniter?
Which two wires? Color codes please: there are several wires connected to the igniter.
Do you realise I was sitting in front of a wiring diagram for the truck while asking questions?
