22rte to a 22re
Old 03-24-2021, 01:45 PM
Jose Torres's Avatar
Smile 22rte to a 22re
Hi there, this is my first thread.
So here's my dilemma, I own a 1986 Toyota Pickup 4WD it came with a 22rte (Turbo Version), but when I bought it had some problems here and there.
The first thing I found out was that the turbo didn't work, IDK what it had but it wasn't spinning anymore, and also it was missing some hoses, so if I wanted to use the turbo I would have to but a lot of parts.
So I removed the turbo, and I rebuilt the motor making it a 22re.
The only problem is that I'm still using the turbo injectors and ECU, and one of these injectors is leaking fuel, I searched in various junkyards and I haven't been able to find the injector. I also tried using a normal 22re injector from the same year but it won't even send fuel in low RPMs.
So I lost all hope in finding this injector, but after searching a lot I found out that there's a way of using high impedance injectors by removing the resistor box, I haven't tried it out, I'm a bit scared of burning the ECU.
So that's what I'm actually doing, I'm trying to find alternatives.
Has anyone already tried this?
Would it work?
Do I have to change more parts in order make this work?
Please help, it's the only thing that's stopping me from driving my truck.
Old 03-24-2021, 02:36 PM
87-4runner's Avatar
What you've done is not going to work...
the 22ret is a LOW compression engine for the boost... different injectors, ECU, heads...
the turbo engine is AWESOME you just need to change a few things and they scream.
your rig is going to be a dog without the turbo!!!
The following users liked this post:
old87yota (03-25-2021)
Old 03-24-2021, 02:50 PM
87-4runner's Avatar
Sorry... your truck is beautiful, and welcome to the forum.
Now. I am very familiar with the turbo rigs as I have 2 and have had one of them for about 10 years and done a LOT of work on it.
The red 4runner is modified with a ct26 @ #10 boost, the white 4runner is bone stock except the oil catch can I added.
Both trucks will BARELY pull themselves without the turbo working... even less power than a standard gutless 22re, and I've had a highly modified 22re ( cam, head, header, electric fan, supra AFM...)
And it was still a dog compared to a nice running stock 22ret. The modified 22ret is killer.
The following 2 users liked this post by 87-4runner:
Jose Torres (03-24-2021), old87yota (03-25-2021)
Old 03-24-2021, 03:44 PM
I know the turbo engine is way better, but I didn't have the money at the time, and a mechanic told me that I was going to spend a lot more money in trying turbo it again, so he recommended making it a normal 22re.
So that's what he did, and I just got it yesterday, it feels really strong because the pistons are a bit wider, the only problem I'm having is that it's leaking fuel from one the injectors and IDK where to buy them.
Do you know a website where I can buy the set of 4 injectors for this truck?
Old 03-24-2021, 04:14 PM
87-4runner's Avatar
Lce
22re performance
yota1
87-4runner's Avatar
LCE
22RE PERFORMANCE
YOTA1
did he put a 22re head on?
you can have your old injectors rebuilt also...
are they 22re injectors or the 22rte injectors?
Old 03-24-2021, 04:16 PM
IDK, I think so, what could happen if he didn't change it?
Old 03-24-2021, 04:18 PM
87-4runner's Avatar
low compression...
Old 03-24-2021, 04:21 PM
I'm pretty sure he did change it then, because like I've told the truck feels great, it responds immediately and with a considerable amount of strength.
Old 03-24-2021, 04:24 PM
87-4runner's Avatar
good deal!
Witchhunter.com rebuilds injectors
Old 03-24-2021, 04:26 PM
87-4runner's Avatar
Use your 22rte injectors and ecu... you should be fine. Send the injectors to witchhunter and they'll be like new.
Old 03-24-2021, 04:27 PM
Originally Posted by 87-4runner
LCE
22RE PERFORMANCE
YOTA1
They're the 22rte injectors, and I already asked someone if they could be rebuilt and he told me that it was too damaged to be fixed.
I already asked 22re performance before if they had the injectors i needed and they told me they don't have them anymore.
I'll ask Yota1 and LCE if they have them in stock.
Old 03-24-2021, 04:31 PM
Smile
I'll ask them if they can rebuild my injector, it would be awesome if they could, thank you.
The only thing that kinda stops me a bit, is that I'm from Mexico XD.
Old 03-24-2021, 04:32 PM
87-4runner's Avatar
Old 03-24-2021, 04:36 PM
I was just seeing the same injectors, I hope they have them in stock.
I'll wait for them to answer me tomorrow.
Old 03-25-2021, 06:28 AM
Numbchux's Avatar
I un-turbo'd my 4Runner for awhile. I swapped in an entire 22RE, as I wanted the higher compression, but I used the RTE injectors, ECU, and AFM, and it ran just fine.
Ask on the "22RTE Turbo Toys" Facebook group if anyone has a good used one.
OE part number is 23209-35020 (looked up using my 4runner VIN on www.partsouq.com. You may want to double-check using your VIN, but it should be the same).
Googled that part number came up with a bunch of information, including: https://www.fiveomotorsport.com/1039...54212181-each/
brock_ryan16
08-17-2014 04:06 PM
WeenieHutJr.
05-10-2013 06:33 AM
callthewrecker
12-06-2010 09:36 PM
govt.mule
03-01-2007 05:47 PM
colsoncj
11
01-25-2005 01:25 PM
Quick Reply: 22rte to a 22re
