22re truck idling weird
Old 08-10-2009, 06:12 PM
93YotaMonster's Avatar
22re truck idling weird, with video
hey guys im having trouble with my truck its idling weird and its running lean.
need some help on diagnosing the problem. hers a short video of what it sounds like, sorry its not a good one but its all i could get http://www.youtube.com/watch?v=-Gk-8mkW8L8
Old 08-10-2009, 06:29 PM
iamsuperbleeder's Avatar
about what RPM is that?
only reason I ask is...
[YOUTUBE]http://www.youtube.com/watch?v=QFUoC9M3JLc[/YOUTUBE]
[YOUTUBE]http://www.youtube.com/watch?v=UdUdBz-v0uo[/YOUTUBE]
and I found a floopy timing chain due to an exploded driver's side guide and a shot tensioner
Old 08-10-2009, 06:35 PM
abecedarian's Avatar
need some help on diagnosing the problem. hers a short video of what it sounds like, sorry its not a good one but its all i could get.
[youtube]-Gk-8mkW8L8[/youtube]
That should help everyone.
Old 08-10-2009, 06:38 PM
uh i really don't no. i think its around 700 or 800 hundred. but i dont have a tach so i couldn't tell you.
Old 08-10-2009, 06:39 PM
First, I'd say... adjust the valves.
Old 08-10-2009, 06:46 PM
ive don it. it hasn't fixed the problem, it had a exhaust leak the same time i took the video. i fixed it and it still sounds the same. dont know what else to do, it just sounds so bad now.
Old 08-10-2009, 06:47 PM
http://www.youtube.com/watch?v=ycAhKsLg3So. hers what it used to sound like, this video is not mine and its not my truck but it sounded just like it
Old 08-10-2009, 06:51 PM
I'll help you out with the youtube once more:
[youtube]ycAhKsLg3So[/youtube]
Old 08-10-2009, 06:52 PM
thanks man
Old 08-10-2009, 06:53 PM
If your's sounded like that, I'd say you have no problems.
It's hard to diagnose lean or rich just by the sound of the exhaust.
ozziesironmanoffroad's Avatar
damn abe, i thought you had left... havent seen a post from ya in a while.
x2 on what abe said.
Old 08-10-2009, 06:57 PM
well it used to sound like that i don't know what happened. it started a few weeks ago.
im just trying to figure out why it sounds like that now. to fix my lean condition im going to try and replace the o2 and see if that helps
Old 08-10-2009, 07:04 PM
Still not sure why you think it's running lean... and not sure why you think a new O2 is going to fix it. If the mixture is far enough out to require an O2 sensor, you'd get a code.
Old 08-10-2009, 07:06 PM
But then I could also add that if it's running lean during a cold start, you may have a problem with the temp sensor or IAV/AAV.
Old 08-10-2009, 07:09 PM
sorry i forgot to add that it is throwing a code 25, witch it running lean. did you mean IAC or IAV? because i have replaced the IAC
Old 08-10-2009, 07:38 PM
Ya know... knowing there was a code involved would've helped a lot.
check for leaks along the intake duct and PCV system. Fix any exhaust leaks between the head and the O2 sensor.
Reset the ECU and see if the code comes back.
Old 08-14-2009, 04:20 PM
ok well i checked for some more exhaust an intake leaks and i dident find any, i checked the o2 sensor out and found that it had ben hitting the exhaust an had some burnt wires so i took it out, cleaned it and fixed the wires. pulled the efi fuse for 15 sec and reset every thing. well ive drove it around for a day now and no codes so i fixed that problem, but i still have the weird idel. i dont no what to do about it, could it be my msd coil?
Old 08-21-2009, 06:34 PM
ok guys my idle is not getting any better it keeps getting lower, and ive adjusted the idle and its not helping. any info would help
Old 08-28-2009, 09:14 PM
alright guys i took the msd coil off and put the stock coil back on and bought new stock wires, spark plugs, and cap. well this did not fix my problem. ive tried spraying carb cleaner along the intake to check for leaks, i haven't found any.,
Old 08-28-2009, 09:18 PM
well earlier i went out side to crank my truck and it just turned over, it would not start so i waited a few secs and tried again still nothing happened so i waited a little longer and tried again and it finally started to fire but it sputterd at first then fired right up. but i noticed it smelled really rich like it wasn't getting spark, but i have a code 25 and that means lean so i dont know what to check, i was thinking it could be my igniter. any help would be appreciated.
Yont283
09-23-2022 08:06 PM
Alex Bessinger
06-28-2015 10:05 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
slider417
06-22-2015 10:18 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: 22re truck idling weird
