22re TPS replacement - now motor surges repeatedly
Old 01-06-2010, 07:09 AM
4Crawler's Avatar
Was this with or without the TPS plugged in to the wiring harness? Might try unplugging the TPS and see how it runs. I know at some point there was a change in the TPS and maybe you are going from an older to a newer one.
Old 01-06-2010, 08:52 AM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
This was with the harness plugged in.
Old 06-09-2010, 12:37 AM
KODE's Avatar
any updates? did you solve the problem??
Old 07-03-2010, 04:24 PM
fork's Avatar
what he said^
I'm getting inf resistance between idl and e2 no matter what gap is between the lever and stop screw. Time for a new TPS?
Old 08-02-2010, 05:00 PM
  #25
WatsonToyota's Avatar
yeah man... what happened????
....he put on a new TPS and started having problems, now if you or I replace one and have the same issues, this thread is of no help lol
Old 08-02-2010, 05:15 PM
  #26
thralldad's Avatar
Wow there are a bunch of TPS threads!
Old 08-03-2010, 05:21 AM
  #27
yo this turned out to be the IAVC went bad at the same time causing a massive vaccuum leak! My throttle problem is still there.
Old 08-03-2010, 10:48 AM
  #28
BigSwole's Avatar
Iavc?
Old 08-03-2010, 10:51 AM
  #29
iamsuperbleeder's Avatar
Originally Posted by BigSwole
Iavc?
It's actually IACV
Idle Air Control Valve
Old 08-04-2010, 07:43 AM
  #30
I am a real ho for messing that one up - sorry
Old 08-04-2010, 07:51 AM
  #31
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
No need to be sorry. It's also called the auxiliary air valve/AAV. Just wanted to throw that in there......
Old 01-21-2012, 12:46 PM
  #32
Dustin Hopper's Avatar
Hey I've had issues with mine too but mine is like lagging whenever I go from first to second and to third and then I have to punch it for it to go anywhere whats the deal?
Old 09-15-2018, 09:10 PM
  #33
Allison Alexander's Avatar
Iac, tps,
BUMP My 94 22RE is doing the same code 22. Got a new coolant temp sensor. Will install
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
Avenged
07-09-2015 07:55 AM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 22re TPS replacement - now motor surges repeatedly
