22re timing set at +15 degrees?
Old 03-02-2007, 06:39 AM
mtrdrms's Avatar
Is this normal? I just got my engine to run and when I checked the timing it is +15 or so? It seems to idle fine.
Old 03-02-2007, 07:49 AM
Yota82's Avatar
Did you jump the diagnosis port prior to checking the timing?
Old 03-02-2007, 09:58 AM
rdlsz24's Avatar
You should be set to 5 degrees BTDC with the engine warm and diagnosis port jumped.
Rob
Old 03-02-2007, 12:31 PM
mtrdrms's Avatar
I did not jump the diagnostic port. Will do and recheck. Thanks.
Old 03-02-2007, 05:16 PM
foot0069's Avatar
FSM says should read between I think 10 & 13 with jumper out at idle
Jim
noahstancik
07-10-2015 11:18 AM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 22re timing set at +15 degrees?
