22RE starts sputtering at 2500 rpms
Old 02-15-2010, 12:32 PM
cuaco-ortiz's Avatar
hi guys, need some help here.
I have an 87 4Runner with the 22RE, it started sputtering from idle to about 2000 thru 2500 (not sure, don't have a tach).
It recently was giving me a problem with a very rough idle, after replacing the fuel filter and checking the fuel pump pressure, it turned out to be a bad connection on the TPS.
But know, the issue is that it still sputters at higher rpms, it seems like its missing either more air or more fuel.
The same thing happens when I'm driving, I can not make it to run faster than it did before, it bogs down, no more power.
Does any one have any ideas?
P.S. I also replaced the ECU and it acts the same way...
Old 02-15-2010, 01:19 PM
Erik Beeman's Avatar
Bench test your O2 sensor(s). they may be bad
Old 02-16-2010, 06:13 AM
hi, thanks for the repply.
See, that's the funny thing, the engine is not putting out any codes, I'm not saying that the O2 sensor can't be wrong, but it just seems odd.
could it be a bad TPS?
Old 02-16-2010, 08:39 AM
Blk63vette's Avatar
Clean your throttle body
Old 02-16-2010, 08:47 AM
there are many things that can make a 22 sputter.
Old 02-25-2010, 09:44 AM
it turned out to be the fuel pressure damper, it was starting to go out (it was leaking gas and I plugged the hole with a screw). I replaced it (expensive little f#$%@r and just as I replaced it, it ran great.
thanks for your posts...
The following users liked this post:
AbeWhat (01-12-2024)
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22RE starts sputtering at 2500 rpms
