22re sensor question
Old 05-14-2010, 12:44 PM
cikphrek's Avatar
I've got an 87 4Runner with 22re. My question is, does anyone know what the sensor is that is located on the lower intake right in the middle? It's located right above where the coolant line attaches to the bottom side of the intake.
Old 05-14-2010, 12:55 PM
mightymouse's Avatar
pics?
Old 05-14-2010, 01:23 PM
iamsuperbleeder's Avatar
sounds like the temp sender for the gauge
just a single wire with a female flat connector on it?
Old 05-14-2010, 02:34 PM
pntbol11's Avatar
yea I think it's your temp. sending unit for the gauge man
Old 05-14-2010, 04:22 PM
cikphrek's Avatar
Yes, one single wire with female spade connector. So that's the one for the gauge. The temp sensor by the tstat housing is just for ECU purposes?
Old 05-14-2010, 04:23 PM
cikphrek's Avatar
And thanks for all the pics of your engine build up superbleeder. Have referred to it more than once.
Old 05-31-2010, 05:35 PM
cikphrek's Avatar
So how many damn temp sensors does the 22re need? There's the gauge sending unit on the lower intake between #2 and #3, the temperature sending unit and the cold start thermo switch on the lower intake right below the thermostat, and on located in the thermostat housing. What is that sensor for? Is this sensor for the ECU?
Old 05-31-2010, 06:35 PM
cikphrek's Avatar
The above post must have auto posted while I was Googleing for my answer. Found it to be the radiator fan switch. I find this interesting since I have the good old fashion belt driven clutch fan.
icentropy
07-14-2015 10:23 AM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
bryan34w
07-06-2015 05:53 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 22re sensor question
