22re to r150f help
Old 07-15-2012, 01:02 PM
Dreidel's Avatar
22re to r150f help
ok so i am in the process ofconverting my truck to 4wd and im trying to decid on a clutch/flywheel/pressure plate combo to use i am going from a 22re to a r150f (the v6 one) if i get the 22rte flywheel, will my v6 clutch an pressure plate bolt up to the v6 tranny
Old 07-16-2012, 06:57 AM
MudHippy's Avatar
The clutch and pressure plate don't bolt to the tranny. They bolt to the flywheel. But that's a little beside the point...actually.
That point being...what you really need is the bellhousing from an R151F(22R-TE 4WD tranny). Because that's what will bolt to an R150F(V6 4WD tranny) and your 22R-E. Or you'll need to buy the adapter to fit an R150F to a 22R-E tranny's bellhousing. Whichever's feasible...
Old 07-16-2012, 03:43 PM
Dreidel's Avatar
ahhhh i meant bolt to the flywheel opps i have the bellhousing (got it off ebay for 100 dollars shipped) not bad imo cause i havent been able to find one for months and i want my 2wd to 4wd project done
i think i might just get a new ceramic clutch and use my same flywheel and pressure plate
Old 07-16-2012, 05:49 PM
XtraSlow_XtraCab's Avatar
Any build thread for this? We almost did this to an 89 2WD, but ended up buying a motorless/trannyless 86 rolling drive train (4WD) and throwing the 89 cab on it.
How will you go about frame modification? The trans crossmember is in a different location and of different size and will the front end support IFS 4x4 arms and torsion bars?
JNapolitano
11-14-2019 07:46 PM
Swim
9
01-04-2016 10:47 AM
ia02
08-20-2015 11:04 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: 22re to r150f help
