22re Oil pump bolts
Old 03-09-2014, 02:55 PM
wyoming9's Avatar
Red face
People get mixed up because the front seal is installed in the oil pump housing Which is much easier to do off the engine.
Then the timing cover has the odd shaped rubber gasket that is round to seal the oil pump housing and the timing cover.
Old 03-09-2014, 03:33 PM
greggyb's Avatar
Thanks for clarifying that for me. So when putting the front seal in the housing, do you normally just lay it on a table to set the seal in? What do you use to drive the seal in?
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
jon.r
07-11-2015 03:34 PM
87blyota
07-10-2015 04:31 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 22re Oil pump bolts
