22RE Missing / Sputtering at Idle!
Old 08-10-2007, 01:28 PM
87TurboYota's Avatar
Question 22RE Missing / Sputtering at Idle!
Well I just bought another truck and I know ya'll are going to want to see pictures but first I need some help.
My truck seems to be running on 3 cylinders but only at Idle while I'm sitting still it'll rock like it has a trick cam in it. But if I give it a little gas at idle it runs very smooth. It has even a few times shut off on me but it doesn't happen often.
While I'm driving the engine runs very smoothly on all 4 cylinders and it is only having trouble while it idles. I replaced the spark plug wires. Anyone had this problem in the past or know what is causing my truck to do this? Thanks Everyone!
Old 08-11-2007, 06:06 AM
Any Ideas?
Old 08-11-2007, 08:29 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Possibly a clogged injector. Not enough fuel being sprayed until you press the throttle.
Old 08-11-2007, 12:12 PM
eightnine's Avatar
yeah im having the same exact problem but mine hesitates a lot when i hit the gas and backfires too, iv already redid the timing chain, bought a new tps and put in a new MAF box. Still runs like ..
Old 08-11-2007, 07:19 PM
frm_808's Avatar
maybe a vacuum leak somewhere? you could try disconnecting spark plugs wire one at a time to see if its a spark issue, if not then do the same to the injectors and disconnect them one by one
Old 08-11-2007, 10:16 PM
86runner_newb's Avatar
try the spark plug wires mine was doing that and i found out one of mine was broken and jumping to the valve cover!
Old 08-12-2007, 08:28 PM
I replaced the Spark Plug Wires and Spark Plugs and it still seems to be doing it. Thats what I thought it was originally. I wonder if it has something to do with the timing. But I'm not sure because when the engine is cold and is warming up at higher RPMs it never misses even if at idle.
Old 08-12-2007, 08:31 PM
Yea I need to check all the vacuum lines because I found one line I believe to be missing. I put a cap on the line with no hose to see how it would react and nothing has changed. Thanks for reminding me I'd forgotten to go back and check that.
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
Sleaker
08-26-2020 06:03 AM
MMA_Alex
25
04-18-2017 05:07 AM
09-04-2015 09:27 AM
Quick Reply: 22RE Missing / Sputtering at Idle!
