22RE Knock Sensor Bypass Harness Connectors
Old 01-18-2011, 06:10 PM
scubarunner's Avatar
I am looking to bypass the wiring harness for the knock sensor on my 88 22RE. Getting code 52, blah blah blah.
I have the shielded wire from Aircraft Spruce, and have removed the metal female spade connectors from their plastic housings. However, I am having a hard time coming up with the metal female spade connectors for either end of the bypass wire. I have combed over mouser and Digikey with no luck finding the exact match. I am looking for the knock sensor side as well as the ECU side.
I'd prefer not to molest the stock harness as it may not be the issue.
This is the one side of what I am looking for. This came from an already spare harness that I had laying around. No ECU side.
Old 01-18-2011, 06:19 PM
xxxtreme22r's Avatar
bypassing a knock sensor is not really a good thing. Why not just replace it?
Old 01-18-2011, 06:28 PM
Not bypassing the sensor, I am bypassing the harness. I am getting code 52.
Old 01-18-2011, 06:41 PM
lol oops thread title got me I guess, but good luck with that one, I hate wiring. lol.
Old 01-19-2011, 03:51 PM
I know this is not a sale thread, but TTT.
I need to find a solution to this. I passed it by a few friends today and non of them came up with anything either.
Thanks,
Old 01-19-2011, 07:55 PM
suprathepeg's Avatar
Are you trying to replace the entire wire back to the ECU?
Old 01-20-2011, 10:27 AM
Yes. Connectors and all.
Old 01-20-2011, 01:20 PM
shaeff's Avatar
Go to your local dealer and grab p/n 82219-89103
It's a pigtail- connector (identical to your yellow one) with a wire lead. You can splice that one up and run a harness straight to the ECU. If you want, I can look around for my spare harness clips and send you a pin from one with a pigtail to solder or crimp to if you'd like. LMK the wire color you're looking for if you want to get all specific. Shoot me a PM with your address.
Actually, I think I have a spare connector kicking around somewhere if you'd like that, too. I can even solder a new pigtail/wire on it for ya if you'd like.
Old 01-20-2011, 01:52 PM
can you make a new wire for the 3vze?
Old 01-21-2011, 05:02 AM
shaeff, Thanks for the offer! I may take you up on it.
I was kinda hoping to avoid splicing and soldering, just rerun the wire using the spare KS side connector I have and get a new ECU side connector to push into the existing ECU plug. I can't believe that I cannot come up with these little metal terminals. Did Toyota build their own?
Old 01-22-2011, 07:49 AM
shaeff's Avatar
You're welcome. Have you tried http://easternbeaver.com/ ?
Old 10-14-2015, 07:40 AM
LVJPW's Avatar
Hey Scubarunner, I know this thread is years old but did you ever fix your knock sensor wire? I don't think my 1986 has a pigtail, I think it's just one long wire from the sensor to the ecu. Can anyone confirm? I'm not sure but I don't think part number 82219-89103 works for a 1986. Any and all comments are appreciated.
steve miller
10-10-2015 01:40 AM
msane99
07-17-2015 10:13 AM
88yodabasket
07-13-2015 01:32 PM
smiley52
07-11-2015 05:16 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 22RE Knock Sensor Bypass Harness Connectors
