22re head rear plate
Old 12-14-2009, 06:28 PM
toyota4x4907's Avatar
Regarding the plate on the rear of the head of the 22re, is there an open oil passage behind it that will leak if the plate is not sealed correctly? Any coolant passages that could spill if I were to take it off for reseal? What actually is behind it? Thanks.
Old 12-14-2009, 06:45 PM
fissure333's Avatar
its a coolant passage
Old 12-14-2009, 07:51 PM
weaselman's Avatar
the plate is an egr cooler. has nothing to do with oil. coolant is behind it. if u suspect it "leaking" oil check the half moon and valve cover gasket that is right above it, making it appear to be leaking oil. lol.
Old 12-14-2009, 08:11 PM
Maybe I didnt fix the half moon plugs enough then
That makes thing a little easier.
06-01-2021 01:51 PM
Colington
03-08-2020 09:51 AM
mskalmus
05-28-2017 07:51 AM
icentropy
07-09-2015 02:12 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: 22re head rear plate
