22re gas mileage, What are u getting?
Old 01-28-2012, 05:26 AM
Pondboy's Avatar
This thread is awesome! I have a 94 22RE stock as far as I know running 31x10.50x15. I average 21-25 highway with a lot of exhaust leaks. Just put in the new engine and fixed pipe leaks. I will post back once i break her in.
Old 01-28-2012, 06:40 AM
CTRJ's Avatar
You all should join Fuelly.com. It's a nice way to track mileage.
Old 01-29-2012, 09:04 AM
toyogus's Avatar
94 reg cab 4x4, with the 22re, 265 70 16 tires, 19mpg city , and hwy. 234k on the clock
Old 01-29-2012, 09:05 AM
dlister70's Avatar
I just got my first Toyota truck.. it's a stock 1992 fuel injected 22re 5 speed 2wd. I got 25mpg on my first tank without a muffler with mixed highway and city driving. Now that the muffler is on, I'm going to shoot for 30mpg.
Old 01-29-2012, 11:01 AM
  #25
dubbsbetty's Avatar
Mine's an 86' 4runner 2.4L 22RE with about 8k on a rebuilt engine, royal purple everywhere applicable, except engine oil(about to change to full synthetic), 5 spd, and 31x10.50x15s with 4.10 gears, LCE header, Magnaflow cat and Flowmaster 40s. Averaging about 18-20 mpg city and 20-25 highway. Usually get up to 25 on the longer highway drives.
Old 01-29-2012, 01:02 PM
  #26
Buck87's Avatar
10K on 22re with full flow cat.
17mpg mixed driving and 22mpg highway
I have a set of 28" tires and a set of 31" tires with 410 gears. After adjusting the odometer reading for the different size tires, I get about the same milage with either set up.
Old 02-28-2012, 06:30 PM
  #27
KRos_+'s Avatar
Id like to see some more please!!!!
Ill post mine when im done fixing my exhuast this weekend!!
Old 02-28-2012, 07:06 PM
  #28
Mashashin's Avatar
91 pickup 22re with 180,000 as of the foot of my driveway tonight when i got home from work. 5 speed, 4x4, 31x10.5R15 tires, swapped the muffler out for a thrush welded muffler last week.
I get about 16.5 to 17.25 mpg right now with the long warmup times, exhaust leak off the header, and a damn CEL throwing a lean code in my face that i CANT figure out for the life of me.
Summer time is much better though, best tank I had was about 24mpg and that was the long haul up to my parents. I made it there and almost 3/4 the way back on one tank!
Old 02-28-2012, 07:11 PM
  #29
drmix's Avatar
Should have made a "3VZE owners BEWARE!!" warning on this thread.
All of the 20+ mpgs are making me jealous
Old 02-28-2012, 07:33 PM
  #30
Crazy Hakachukai's Avatar
81 Toyota 5 speed
Around 20mpg's in the city
Completely stock
New Head gasket
New spark plugs, wires, distro cap and button
Used head
New gaskets and seals of every kind
New muffler
Old 02-28-2012, 09:10 PM
  #31
bob200587's Avatar
I've tracked statistics for for over 7 years now.
22re w56 trans, 4.10 gears 31" tires. Averaging 17.75 mpg with 93 octane fuel.
Old 02-28-2012, 09:58 PM
  #32
malteserunner's Avatar
Getting 20 mpg on the new engine. 22RE, W56, 285/75R-16 BFG A/T's, 4.88's, Supra AFM, Downey header w/2.25" exhaust, Engnbldr Street RV head w/268c cam, balanced and bored 0.020" over, 87 octane Chevron and Lucas Upper Cylinder Lubricant every tank.
Old 02-29-2012, 04:17 AM
  #33
flash02's Avatar
Originally Posted by AK01Runner
I started keeping track of my 92 22RE manual. I get around 17-18 MPG in winter and 21-23 MPG in summer. Almost all city driving, but some highway in summer. The subzero temps really cut down on MPGs. Plus I'm in 4HI most of the time in winter. Here is my log from last Feb through July.
266.5/14.05=18.9
259.7/14.08=18.44
259.3/12.70=20.41
295.1/13.31=22.17
299.4/14.22=21.08
300.4/13.52=22.21
199.8/8.5=23.5
315.8/14.07=22.44
311.8/13.24=23.54
Your mpg dropping in the winter is probably due to the 4high, colder temps mean denser air = better performance, I would think better MPGs....good MPGs
Old 02-29-2012, 06:12 AM
  #34
drmix's Avatar
Plus they use different fuel during the winter which lowers your MPG
Old 02-29-2012, 06:25 AM
  #35
flash02's Avatar
Yeah I did not even think of that, I know the crappy E10 where I live kills my MPG in the yota and my Subaru WRX. Funny the owners manul for my 4Runner specifically states NOT to uses any fuel with methanole, and if you must then at the first chance fill up will 100% gas. There is one gas station where I live that still sells 100% gas, both cars get better MPGs.
Old 03-02-2012, 01:37 PM
  #36
86YodaForce's Avatar
Hook me up with that spread please?
Old 03-02-2012, 01:39 PM
  #37
Nice spreadsheet
Can ya share that spread sheet?
Old 03-02-2012, 03:49 PM
  #38
dakotawho's Avatar
about 16mpg all around.....thats a 5-speed, rebuilt Jasper motor, 32x11.50's, oh and the biggest lead foot you ever seen
....and thats mid grade to premium gas:/
Old 05-19-2012, 08:06 AM
  #39
KRos_+'s Avatar
mostly stock 5 spd, 410 gears, 30x9.50 tires, Unknown mileage, No cat w/ cheap summit muffler and straight exhaust. Odometer is broke so its hard to be exact but ive been using gps unit and calculated im getting around 15+mpgs/city. I havent done enough highway driving to know highway mpgs. But it seems good.
Keep this thread alive!!
Check out my build up thread!!
https://www.yotatech.com/forums/f116...ration-252257/
Old 05-19-2012, 09:15 AM
  #40
gottadog's Avatar
87 long bed, about 5k on the rebuilt 22re, auto to manual swap last month.
before the swap I struggled to get 15mpg with the auto. Now with the w56 and synth gear oils, I'm getting 23mpg easily on the HW.
In my opinion you guys with stock gears and larger tires, shouldn't be posting your inflated MPG without GPS or at least mapping out the mileage online and dividing the fill up.
Quick Reply: 22re gas mileage, What are u getting?
