22r whining noise, then oil light came on and truck shut off
Old 09-28-2012, 08:59 PM
Tkeehr11's Avatar
Hey guys.87 yota with a 22r. So here's the story I was driving down the road and my truck started making a whining noise, Once it got louder my oil light came on and I began losing power as I got off the freeway then it died. I had it towed home and when I got there I drained the oil and the oil looked fine with no metal shavings in it and not milky at all. Truck will start but not stay running and continues to whine. Can not figure this one out. The truck has a new timing chain,oil pump, water pump, front main seal and harmonic balancer, please help!! Again it's a 22r
Old 09-28-2012, 10:16 PM
tbmckinley01's Avatar
Check the oil filter, cut it open and check if there is metal inside.
Old 09-28-2012, 11:44 PM
Tkeehr11's Avatar
Ill head out now and see, if so what does that mean, also if not what does that mean? Thanks a lot for the help
Old 09-29-2012, 12:43 AM
Tkeehr11's Avatar
No metal in the filter
Old 09-29-2012, 09:02 AM
xylicon's Avatar
At this point if it were me, I'd remove the valve cover just to do a quick inspection. Then I would do a compression test then go on from there.
Old 09-29-2012, 12:15 PM
Discombobulated's Avatar
what kind of motor again??
Sorry I had too
Old 09-29-2012, 12:17 PM
swampfox's Avatar
Was the chain guides broke when you replaced them, and did you clean the oil pickup screen ?
Old 11-08-2012, 08:26 PM
Tkeehr11's Avatar
Haha discombobulated I'm used to dealing with retards on Craigslist not talkin to ppl that know their stuff ha, ended up being a crack in the intake. Fixed her up sold it and now time to dump money into my 85. Thanks for the input guys
Old 07-13-2013, 01:48 PM
Pick-rolla-Pick's Avatar
Could you please clarify exactly what you mean by "intake"? Was it the intake manifold or just an intake hose?
I am having similar symptoms with an 82 pickup with 22R. It used to just occasionally not hold idle after starting it unless I held the gas pedal down, but lately I've been hearing a faint whine and today it started dying while driving it down the road at 45 MPH or so. I left it running and popped the hood when I got home. The whining seems to be coming from right under the air filter canister. I'm going to check again for dust buildup somewhere, which is often a sign of a leak.
voiddweller
19
05-02-2016 09:10 PM
serenity03k64
06-27-2015 07:59 AM
paxanders
06-21-2015 06:29 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: 22r whining noise, then oil light came on and truck shut off
