22r vac lines and electric fuel pump conversion questions
Old 07-06-2013, 06:02 PM
nacy369's Avatar
Am I okay to delete all my vac lines other than brakes and dist? And just plug the other spots on the carb?
I'm converting to a electric pump with a regulator and I'm wondering what I do with the return line. All help very much appreciated. And yes I have searched and I have an idea I just need some confirmation
Old 07-08-2013, 08:36 AM
nacy369's Avatar
I know its a dumb question so someone give me a dumb answer.
Old 07-08-2013, 08:52 AM
Stetson_md's Avatar
I don't know but I know who dose kawazx636
Old 07-08-2013, 02:38 PM
nacy369's Avatar
im gonna run a mr gasket pump and regulator. its a inline regulator with no return, do I even need a return? If I do how would I work that in?
Old 07-09-2013, 02:58 AM
Stetson_md's Avatar
If your electric setup kicks on and off or adjusts to match what the carb needs as it needs it I wouldn't think you'd need a return line but if it comes on and stays on like a mechnical pump you would need it to keep from floodin the carb but I ain't no mechanic. Hopefully someone else that knows will help you out
These might help you out if you haven't already read themhttps://www.yotatech.com/forums/f114...ly-22r-205845/
https://www.yotatech.com/forums/f114...torial-264405/
Charecter1
11-06-2023 10:08 AM
bigjstang
08-25-2021 12:41 AM
coryc85
09-09-2015 06:24 AM
Yota.Jay
07-23-2015 08:08 PM
TURBOrunnerNM
07-22-2015 11:01 AM
Quick Reply: 22r vac lines and electric fuel pump conversion questions
