22R swap...Need a shop to re-tune
Old 09-07-2010, 08:35 PM
YotaFamily09's Avatar
The 22R (carb) in my '87 spun a rod bearing at 223K (someone along the line forgot to change the oil) so I traded for a 81 complete motor with only 5k on it after a complete rebuild with an upgraded valve train (stock ratio rockers, springs, and a custom Crower Cam). The 81 had a CA smog legal Weber set-up that i had to ditch and go back to the 87 smog junk so it would pass smog. It runs ok, timing is set at 5º and the carb is a little rich for safety purposes. My question is, does anybody know of a shop in southern Cali that can do an accurate tune on a '87 carb set-up so that this thing runs great? Any help would be great.
Old 09-07-2010, 08:57 PM
myyota's Avatar
There`s not much to tune up on a 22R, make sure the timing is set right, adjust the valves, new plugs, plug wires, cap and rotor, and that`s about it. Also make sure the vacuum hoses are good and hooked up properly.
Old 09-07-2010, 10:28 PM
Very true, but I am pretty sure that the stock carb will need to be re-jetted because of the cam. I checked the valves when I installed the engine and they are adjusted properly. Only thing I am dodgy on is the vacuum hose routing. I am pretty sure that it is not 100%, I have worked only older carbs with A LOT less lines and newer cars with almost no vacuum hoses, so this mid eighties carb spaghetti mess confuses me like a fat kid in candy land.
Old 09-07-2010, 11:20 PM
myyota's Avatar
Yea, no joke on all of the vacuum lines on these engines, but if there not hooked up right it can cause problems. Down load a FSM and it will have a diagram of the vacuum hose routing.
Jcrawl94
10
10-24-2015 04:34 PM
noosh
08-21-2015 03:49 AM
auscal
08-19-2015 11:00 AM
skeeter0288
08-16-2015 09:40 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Quick Reply: 22R swap...Need a shop to re-tune
