22R Rebuild
Old 10-12-2009, 02:34 PM
  #61
flyingbrass's Avatar
BTW, a bare 22R block weighs about 89 lbs.
Old 10-12-2009, 03:00 PM
  #62
My alternator is filthy with caked-on grime inside and out. What's good to use to clean it up without hurting anything, including the coating on the windings? Electrical contact cleaner?
I'll probably replace the brushes.
Old 10-14-2009, 04:30 PM
  #63
yodta's Avatar
Originally Posted by flyingbrass
regarding the junk you found in the pan afterwards, I just thought I'd share what I found in mine when I pulled the engine on my first Toyota truck, which was a 2wd model. the P.O. had torn into it at least once. I'm guessing it was for a broken timing chain, as, in addition to the little beauty shown below, there were several curious tiny metal "sleeves" in there too -- they were the spacers between the links on the chain!
in case you don't recognize it, this is one of the timing chain guide bolts. I can only presume that the guide broke, and the bolt rattled loose. from the looks of it, it may even have been the cause of the broken timing chain, the bolt having fallen right down into the works. can only imagine what sort of noise or mechanical mayhem that caused.
Old 10-14-2009, 04:53 PM
  #64
Blk63vette's Avatar
Originally Posted by scroungecat
how can you tell if a motor was rebuilt? I got this motor from a tweeker he said it had a bad head gasket messed up timing chain any ways he said it was rebuilt but i dnt trust tweeks the odometer said 267 thousand so i pulled the free motor any suggestions
Dude why are you buying a engine from a tweeker??
Old 10-15-2009, 03:21 PM
  #65
Ouch. That'd ruin your day. Is it advised to use blue Loctite on those and/or the tensioner bolts?
I cleaned up my engine compartment. A battery had a problem before I got the truck, so that area won't look nice unless repainted. I doubt I'll bother. The rest isn't iamsuperbleeder kind of clean, but better than it was.
As I got done spraying everything off I found the pencil end I had stuck in my fuel line had fallen out. I think it's the intake, not the return. I don't know how much water got in, so I'll siphon some gas through to flush the line when I replace the hose.
Old 10-15-2009, 04:55 PM
  #66
yodta's Avatar
mmm, not sure about the tensioner bolts, but I can't see it hurting anything on the chain guide bolts.
just wire brush it, blow it out with air, and then hit it with some primer and/or some Rustoleum.
Old 10-22-2009, 02:34 PM
  #67
The machine shop just called. The guy was amazed how great my block and pistons are, even asking when it was last rebuilt.
He said I can either use iron rings with my existing pistons or bore over and use moly rings on new pistons. He said iron rings would last 90K-100K miles.
The block needs to be decked by .010" to .012". I'm thinking that much with stock pistons would result in too much quench, particularly since mine were above 0 to begin with. Aftermarket pistons are destroked by about .012" to accommodate decking.
So, should I keep my OEM parts and use iron rings, or bore .020" over and buy a master kit from Engnbldr?
I asked about the groove in my crank. The machinist said to leave it alone and that a newer double lipped seal should seal fine.
Old 10-22-2009, 02:58 PM
  #68
Here is #4 before teardown.
Old 10-23-2009, 02:46 PM
  #69
I e-mailed Ted. He advised using new pistons, so today I ordered:
street/rv head
268 cam
master kit (pistons .020 over, others standard)
timing cover
head bolts
water pump
Came to $886 shipped. My order should ship Tuesday.
So far, I've spent a lot more time researching, learning and waiting than wrenching.
Old 10-23-2009, 04:10 PM
  #70
toyospearo's Avatar
Nice work man!!
I am doing a timing chain with a friend next week on a 22r. It will be the second one I have done. Your pictures will be a big help.
Great job. Keep up with the pics!!
Old 10-23-2009, 07:46 PM
  #71
Staceman1's Avatar
Excellent! Your motor is gonna be better than new. Gonna do this again in 25 or so years?? Keep up the good work, and give us a pic of the new head, as well as the naked block when you get it back from the shop. I love engine porn!
Old 10-25-2009, 12:33 AM
  #72
I hope you're right. Time will tell.
25 years from now? If I'm still alive I may be learning and asking about retrofitting a fuel cell or whatever other power tech is popular into an old Toyota.
I'll post pics when the parts arrive.
Old 10-26-2009, 07:28 AM
  #73
cgeorge's Avatar
YOu mean FLUX Capacitor!!
This is a great thread... I'm picking up a 1990 Pickup 2wd today.. hopefully it won't need this much work but if it does - I'm printing this thread!!
Old 10-30-2009, 03:24 PM
  #74
My parts from Engnbldr arrived today. I've been sick with flu this week, and it still hasn't let up. I got worn out just hauling in the boxes. I haven't looked at everything yet. I will later and post some pics. So far, the only issue I've noticed is with the timing cover. More on that later.
I noticed Putney's Custom Machine has put up some interesting Youtube videos: http://www.youtube.com/user/putneysc.../4/iPOJXDyw0F4
The instructions in Engnbldr's timing kit say to install everything, tape the tensioner back, and slide the upper timing gear on the cam. Make sure some clearance exists between driver side guide and chain (the guide can be adjusted a little). So, that means install the head before the timing cover. I had it in mind that the head would go on after the cover. Any thoughts?
Old 10-31-2009, 05:53 AM
  #75
I went through most of my parts. The head will have to wait. I'm worn out. Flu sucks.
The pistons look good. I don't have any way to measure them precisely. On my kitchen scales they weighed: 425g, 425g, 423g, 424g. That's a little under half a percent spread. Seems pretty decent to me.
The water pump looks good and spins about the same as my old Aisin.
I'm not impressed with the oil pump. My original Aisin's clearances measure within spec. The Rock is at the outer limit between crescent and outer gear at a full .012". That's the max allowed. Range is supposed to be .0087" to .0098". Inner gear to crescent is a little on the tight side at .003" (range .0059" to .0083" for that one if I'm understanding the manual correctly). Plus, the timing number area is chipped and difficult to read.
Compared to my old one on top.
The timing cover also isn't very impressive. What at first glance looked almost like cracks in places are actually small ridges. Sort of an eggshell effect . The oil passages to and from the oil pump are quite rough. Most of that is cosmetic. The potential functional issue is the water pump mating surface is not completely flat. A portion at the top wasn't milled to the same depth as the rest. It's hard to show in pictures, but here are a couple:
I don't know if the step is bad enough to cause an issue. It is a little concerning. I've read many advocate putting the water pump gasket on dry. I'm not sure a gasket by itself will seal in this case. My pump didn't have a gasket, only orange FIPG. Any opinions? I need to decide whether I'm going to use this one ASAP. The shop is waiting for me to bring parts.
The only thing wrong with my original cover is the radiator hose tube is badly corroded. In the worst spot it's very thin, almost all the way through. Strange how it corroded like that under the hose.
Old 10-31-2009, 06:04 AM
  #76
92 TOY's Avatar
I am alot concerned about those pictures, cosmetic or not.
I have heard only the highest praise for ENGNBLDR on this site. I woud think that you should contact them and voice you concerns. Myelf as a non-mechanic, I am concerned that you picked up all those irregularities / deficiencies whereas I may not.
Please post what you are going to do. I know you said that the shop waiting for your parts, but I'm sure you aren't their only income and you should have complete confidence in what you are bolting on 1st.
Old 10-31-2009, 06:39 AM
  #77
I just e-mailed Ted.
I'll probably reuse my old oil pump. I didn't really even want a new one, but it came with the master kit.
Not sure what to do about the timing cover. If worse comes to worst I'll find someone to weld up the corroded part of mine. New Aisin covers cost about $120.
Old 10-31-2009, 06:45 AM
  #78
BTW, I'm not a mechanic. Those oil pump specs are in the FSM, and I was curious. Look in the specs section near the back.
Old 10-31-2009, 08:13 AM
  #79
sb5walker's Avatar
Sounds like reusing the old pump is the way to go. It's pretty bad that the new pump is out of spec - that does NOT reflect well on Rock parts. You absolutely should not have to pay someone to repair a brand new part (the cover) that you just bought. Talk with Ted and tell him it is not acceptable and I'll bet he'll take care of you - at least he might sort through his covers and find you a less bad one. It sounds like he needs to source parts somewhere else.
Old 10-31-2009, 08:21 AM
  #80
My old Aisin cover is corroded where the radiator hose attached. Apart from that, it's fine. It's the one I'd try to repair.
The Rock cover has a small step (about .003" higher) in the upper part where the water pump attaches. And it's generally messy. I'll clean up the inside if I use it. Some of those "ridges" flake off with a fingernail.
Quick Reply: 22R Rebuild
