22R Carb To Weber 38
Old 03-24-2008, 03:00 PM
dewitt88's Avatar
What kind of diffrence am I looking at?
I have never owned carbs before and my 22R carb is shot. I am getting the 38 tomorrow and I Would like to know what to expect from the swap? Thanks
Old 03-24-2008, 03:08 PM
cutboggers's Avatar
alot more power with less throttle. I personally stand beside these carbs. although mine currently went JUNK. :o)
Only prob i had was overfueling. Blew alot of black smoke along truckside by the exhaust. I'm sure that could be fixed with a little jetting.
another thing is you will need switched 12v wires cuz this carb has 2 solenoids that are required for proper function.
Old 03-24-2008, 03:17 PM
dewitt88's Avatar
I am getting it from a guy that used it on his yota rally truck. Comes with intake, he said all I need to do id hook up vacuum and fuel and I was good to go.
I dunno I will figure it out. 6 months old with intake for $150
Old 03-24-2008, 03:18 PM
cutboggers's Avatar
deal of the day man. you'll like it if it works for ya i garuntee it. It's 20% more power than any carb i have ever ran. 32/36, 34/34, rochester
Old 03-24-2008, 03:20 PM
dewitt88's Avatar
well this is what I got now (MESS)
Old 03-24-2008, 03:24 PM
cutboggers's Avatar
yep. You only need one of them small lines. Will look alot cleaner when your done
Old 03-24-2008, 03:35 PM
dewitt88's Avatar
Yeah I am going to have a time figuring this out being I am new but I am sure with all yall here I'll figure it out. Since I alread have old pics here I will put all new info here tomorrow. Thanks
Old 03-24-2008, 03:36 PM
Sponsor
Tofer's Avatar
where did you get the webber? i need to clean/replace my carb.
Old 03-24-2008, 03:38 PM
dewitt88's Avatar
Local guy here took it off his rally truck.
Old 03-24-2008, 04:23 PM
86 yota's Avatar
What kind of mileage are you guys experiencing from the 38 weber? I thought about it but, if it kills the mileage then you might as well throw in a 350.
I pull a lawn trailer and am looking for more power but do not want to loose my good mpg when on the highway and around town without the trailer. Thanks
Old 03-24-2008, 04:40 PM
dewitt88's Avatar
I Will be doing the install tomorrow and I will know more about milage in a week or so.
Old 03-26-2008, 01:16 PM
dewitt88's Avatar
Update...I got the carb and high rise on today. It runs much better but I cannot figure out where the 1 vacuum line by the adjust screw goes? It runs fine without it hooked up just a odd idle...Where does this hook up?
I thought it hooked up to the vacuum thing on the dist cap but there is 2 lines there and I dunno which one to hook it too. I took off all emissions and unused vacuum lines and blocked the whole in the head off. Its louder and even with the loose vacuum line it will jump up and run. I just need some help hooking that line up.
Will get pics if anyone is intested...My egr block is homemade and will be there until I get the one I order. I used a piece of 16GA metal stud, a chopsaw and grinder to get it to cover the hole and bolt up. Soon I will be doing a valve adjustment. Thanks all for any help
Old 03-26-2008, 02:25 PM
dewitt88's Avatar
No one has any idea?
Old 03-26-2008, 03:47 PM
cutboggers's Avatar
there are two on your dist. hook it to the closest one to your radiator
Old 03-26-2008, 03:54 PM
dewitt88's Avatar
Ok cool...
What does that do lol?
Do I need to plug off the other one?
Old 03-26-2008, 04:00 PM
cutboggers's Avatar
for the vaccum advance. Pulls distributor when throttling hard for advanced timing for more power on the top end. No need to plug the other unless your planning to do sum serious water forging
Old 06-21-2012, 08:20 PM
rednecktruck22's Avatar
Any Pictures?
Old 06-21-2012, 08:39 PM
cman1's Avatar
thread is 4 yrs old.
Old 06-21-2012, 09:12 PM
fork's Avatar
it might be old but you never know... maybe the OP is still active and has some pictures. I wish I could afford to rip the EFI from my 22re and throw on a 38/38 or DCOE's
buckz6319
08-05-2017 03:50 AM
Iceman4193
10-16-2015 10:50 AM
alexcarey
10-14-2015 06:05 PM
Toys4parts
09-26-2015 01:56 PM
taraf
09-25-2015 02:57 PM
Quick Reply: 22R Carb To Weber 38
