22r boggin' out
Old 02-21-2007, 08:25 PM
Kevin286's Avatar
Not to knock the excitement over the vaccum lines, but I didn't see it mentioned that he has two fuel filters. The one by the gas tank he covered, but what about the one between the fuel pump and carb? Mine is a few years older, did the newer models not have one?
My truck, 83 hilux was giving me almost exactly the same problem as described. Running perfect, then under a long load, like driving up a gradual hill, it would fade out, like I was out of gas. Would start up fine after. I removed the fuel filter at the tank, (easier to push gas then suck it) and replaced the one between the fuel pump and carb, with a decent, high flow filter.
Whatever it turns out to be, keep us posted.
Old 02-21-2007, 08:37 PM
86toysr5's Avatar
im dont bog out and i no sum of my lines r messed up i think my fuel line r mixed up but it runs.....22r pumps r setup diff then 20rs
Old 02-21-2007, 10:54 PM
deathstalker's Avatar
ok, here's what i need to know. See this guy here:
See how the hose goes all the way around and plugs into the thermo valve. right now i have the one circled in red in the last post plugged into that (the one coming from the carburetor)
The one that is supposed to be going to the thermo valve is currently plugged into the air filter assembly near the side. There's a spot for a small hose there, marked in red on the following pic:
If i get a splitter so i can hook the one from the carburetor properly AND i hook the other one properly into the thermo valve, what am i supposed to plug into the air filter assembly?
I see from my book that there is a hose plugged into there. It just doesn't tell me which one, of course.
Hope this helps. I was having a little trouble describing earlier.
Old 02-22-2007, 12:25 AM
drew303's Avatar
not sure im following here...
Hook the hose (like shown in the pic i posted).
the skinny one on the pass side of the carb hooks into the shroud right where you have the red line.
I dont know what other hoses you havent hooked up at this point? Theres only two hoses that hook into the shroud I think.
man ill have to look at my engine tomorrow im confused lol
I two trucks, one is cali- and one isnt, both 87 22rs
I never had so much trouble with the vaccum lines, they all seemed (both engines) seemed straight forward lol
Old 02-22-2007, 12:26 AM
  #25
drew303's Avatar
buy a splitter at a parts store. should have one.
You said pre-owner messed with the lines so its possible the engine is missing hoses and parts (like that splitter).
Old 02-22-2007, 12:27 AM
  #26
drew303's Avatar
Also, the lines that go to the thermo, mc valve are hard lined and built into the shroud, theres a skinny line that stretches out to the HAI tho.
the diagram above isnt really accurate sicne you cant actually see the line that goes tot he thermo from the carb connection.
Old 02-22-2007, 09:13 AM
  #27
Kevin286's Avatar
I posted up the Emissions section out of my 85 FSM. It has all of the vaccum diagrams.
Linky
Old 02-22-2007, 09:41 AM
  #28
i can't use file factory at work. i'm posting more pics in a minute...
Old 02-22-2007, 09:50 AM
  #29
here's the bottom of the shroud, assembly, whatever it's called:
The top is where the skinny tube on the pass side hooks in, correct. Like here:
And the bottom is where the larger tube hooks in, on the white part, correct? Like on the box here:
The circled part on that picture is where i'm having the confusion and where this tube is currently going:
Does this help?
Old 02-22-2007, 10:14 AM
  #30
drew303's Avatar
I'll have to go look at mine but i dont remember that white connection.
but i know the hose
doesnt go there =)
Old 02-22-2007, 10:47 AM
  #31
I don't think anything goes into this. this doesn't lead anywhere. it goes straight up inside the shroud and has a little opening that isn't even big enough to hook a hose onto.
Old 02-22-2007, 11:06 AM
  #32
drew303's Avatar
alright i figured it out. I was giving mis info..
Old 02-22-2007, 11:08 AM
  #33
drew303's Avatar
The hose (skinny thing you said just dumps into the shroud). Thats capped on the Cali models.
I didnt get a good picture of the thermo valve plumbing, sorry. If you need one just holler.
Old 02-22-2007, 11:11 AM
  #34
drew303's Avatar
on non cali models that isnt capped, theres a thing called a VCV that connects into that (whats capped).
Old 02-22-2007, 11:17 AM
  #35
drew303's Avatar
More information:
And here is how it hooks into the carb.
Old 02-22-2007, 11:39 AM
  #36
awesome, awesome, awesome. That fixes everything. I'm going to run at lunch and get a splitter for the hose coming off the carburetor and a cap for the other one.
thanks, dude. i'll let you know how she runs after and hopefully tonight i'll raise a beer in celebration.
Old 02-22-2007, 05:52 PM
  #37
damn. i mean damn. it feels great. when i started it after work, it took some time to warm up, but once it warmed up...i dunno...it felt TOO powerful.
only thing is it seems like it idles really high, but it's holding strong and doesn't feel like it's gonna die on me.
lol, i'm probably just used to having a messed-up truck, but this does NOT feel like the same truck. talk about torque.
Will keep you posted after timing. gonna go for a drive and have a beer!
Old 02-22-2007, 07:16 PM
  #38
drew303's Avatar
You can adjust the idle pretty easily, it's just a screw on the throttle. =)
Old 09-05-2016, 05:58 PM
  #39
Edgar Jauregui's Avatar
Where can I get a new MC Valve for my 22r ?
buckz6319
08-05-2017 03:50 AM
Iceman4193
10-16-2015 10:50 AM
alexcarey
10-14-2015 06:05 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: 22r boggin' out
