20r head swap onto 22re
Old 05-02-2010, 07:27 PM
toy-yota7's Avatar
Has anyone hear that the 20r head puts out more compression then the 22re. and you can swap them and they bolt up easily? any input will help thanks.
Old 05-02-2010, 07:39 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
any researching on your part would help to...
No, I wouldn't do it... B/c the pistons take up way less space, but you can do it...
22R pistons are bigger and just barely fit inside the 20R chambers... That = high compression.
And the biggest why I wouldn't do it, there is no way to put EFI on a 20R head... Yet...
Using a 20R Head on an 85-95 22RE Block
Now if you had a 80-84 22R block and were carbed, that's another story...
Old 05-02-2010, 07:44 PM
toy-yota7's Avatar
thanks
yayfortrees's Avatar
Sounds like a can of worms and lots of headaches to me.
Old 05-02-2010, 07:47 PM
Bullrider_5406's Avatar
Yesit does have more compression and can bolt up but i would put 20r bearings in the lower end and if you port and polish it so that it is not round they really run good
Old 05-02-2010, 09:02 PM
toy-yota7's Avatar
so you can or can't use a EFI?
Old 05-02-2010, 09:09 PM
nothing odd about that post...
No. There is currently, 2MK, no ECONOMICAL way to use EFI with a 20R head...
Though there is a guy here with a post looking for feedback on making an adapter...
Which would be cool b/c of the Turbo applications...
Try googling "20R EFI" see what you come up with... who knows?
amazing question answerer that google...
Old 05-02-2010, 09:58 PM
toy-yota7's Avatar
so looked around a little bit and found this
http://sdsefi.com/techinta.htm its a site on how to build your own intake.
Old 05-02-2010, 10:06 PM
ok, I'll do some more...
You'd be FAR better off just to buy high compression pistons from LC Engineering, unless you're a master fabber...
1, 22RE pistons are almost flat top pistons.
2, (80-84) 22R have a high crown or ridge on the top. Some may call them high top pistons, but it's a bowl more than just straight across...
3, The 22R block was de-decked in 1985 so any head after that will have to be machined... A LOT.
4, You're removing mass and it's a fairly complex and costly task, so what's the point.
5, The 20R chambers are 80/82 cc's. So I'm almost positive you can't machine off enough surface to account for the loss in mass the "high Top" of the 22R pistons displace... So there is no way the compression will be as high as it is, using the correct high-deck 22r block
Old 05-03-2010, 04:49 AM
iamsuperbleeder's Avatar
so let's sum it up
yes, it's been done in the past
it will in fact bolt to the block, but it's all the other little factors that make it not your average bolt-on
Old 08-26-2019, 04:13 PM
babydavis's Avatar
Try lce sidedraft efi for 20r head for it but I think the best way to use it would use a after market ecu like haltech or megasquirt for the efi, spark, and timing. I'm thinking about doing it myself for a project but I'm not to sure yet. I'm not sure about my budget or how much I want to have for power low and high end and even torque. I have to do a lot more research on my part for air to fuel ratios and how to control the spark and timing.
Colington
03-08-2020 09:51 AM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 20r head swap onto 22re
