203HP 22re
ya true. but the motor was used when he bout it but he put a bunch of parts from trd and ported the heads, and intake. he rebuilt the entire motor and opened the cylinders a bit
To compare, find an 8-valve long stroke motor.... Not fair to compare with a more modern multi valve/cam motor...
Ask for a dyno run out of that shop, but don't discount the HP added by green paint.
#25
91toyota I wouldn't even chance it with this guy, I have seen I don't know how many people on craigslist fighting with this guy because they had problems with his motors and some said that when they tore them down to find the problem the motor hadn't even been rebuilt just cleaned up and put back together. If it had only been one person I would say maybe his motors our ok, but it has been quite a few different people complaining.
#26
#28
Not very likely
It's conceivable to get that power from one of these engines but your talking some serious port work and pretty high compression. As well as rpm in the 7000-7500 range. I'm thinking it would cost a lot more than they are selling them for.
Besides the engine, the engine management system would have to be upgraded
Maybe they figure the pretty paint increases volumetric efficiency
#29
well we all know that green paint, due to the shorter wavelength of the light reflected by it, produces less obstruction and turbulence to air passing around it than what is caused by orange, or even worse- red paint. That's why Ford uses blue- even shorter wavelength than green. The fastest engines don't use purple or indigo though, even though purple and indigo are even shorter wavelengths than blue... black is the preferred color for the fastest engines since black means there is no light reflected and consequently no turbulence and therefore produce the most power.
#31
It's like those Turbonator/Tornado thingies (technical terms) More turbulence=fast,,,,,REAL FAST
#33
