1st Gen 4Runners: Low Fuel Light
Old 03-21-2012, 10:35 AM
motocrossaddict223's Avatar
my 88 4runner (sr5 3vze) has one but the gauge is so far off i can drive 40 + miles once it says e then the light comes on them will shut off and i have about 2.5 gallons left.
Old 03-21-2012, 10:55 AM
Philbert's Avatar
My 87 4runner has one and it works...slowly comes on.
Side note.....I've noticed that some time years ago, my 4WD indicator lights on my SR5 gauge cluster stopped working. Lights are new, and 3WD DOES ENGAGE. This was on my earlier transmission, and now with the replacement one I put in last month - 4WD is on, but the light doesn't indicate that.
Any idea what it could be? Sensors are plugged in....what would I test for, either at the transmission or at the cluster, to see if the right signal is being sent or not?
Not a must have, just curious since we're on the topic
Old 03-21-2012, 05:34 PM
Bassmastry101's Avatar
I caught the light in action! Apparently this is a rare event lol.
Old 03-21-2012, 05:46 PM
stanz's Avatar
Even more rare than that is your altimeter that displays photos of girls. Must have been limited edition option.
Old 03-21-2012, 05:52 PM
  #25
HAHA I didn't even see that. My girl looks better than the altimeter anyway
Old 03-21-2012, 06:11 PM
  #26
Turd Furgeson's Avatar
My 87 turbo p/u is not an sr5 and it does have the light......it's on all the time and the gauge is always on empty. I'm hoping it's as easy as replacing the sending unit and it's fixed.
Old 03-22-2012, 03:18 AM
  #27
That's just because turbo trucks are awesome enough that they don't need the sr5 package lol.
Old 03-26-2012, 11:31 PM
  #28
weaselman's Avatar
my 86 sr5 4 runner had a low fuel light, it came on very slowly and went out and came on very slowly (fuel sloshing around moving the sender)
and my 87 Turbo 4 runner has a low fuel light, although. once it comes on, it stays on.. once the light comes on, i can go exactly 25.4 more miles till the truck dies. haha.
Old 02-19-2014, 03:27 PM
  #29
tinigunner11's Avatar
In the months I've owned my truck I've only seen the light come on twice and then it shuts off. I caught the light in action today
and then this light came on and shut off.
Old 02-19-2014, 06:25 PM
  #30
RustBucket's Avatar
My low fuel light shares the Charge light for some reason.
Old 02-21-2014, 01:18 PM
  #31
skypilot's Avatar
Low fuel is float switch in the tank. Part of the level sensor so you have to drop the tank to fix it.
Old 02-21-2014, 06:46 PM
  #32
stanprophet's Avatar
Originally Posted by BMcEL
I should mention that when it comes back on the second time, it stays on until I fill it back up. What's weird is it stays off for a good 5-10 miles of driving before coming back on the second time, which makes me think it's not just the gas sloshing around. It's done it since I bought it in 2004 and I've put over 100k miles on it since then. Based on the FSM testing procedure, there's really no way to tell if the switch was engineered to give first and second warnings or if it's just a worn spot.
I don't really care but it would be cool if someone actually knew the answer to this.
Neither, it is more or less a moisture sensor, it detects when it is moist and when it is not. Chances are living a very long life in a hellish environment has taken its toll on the little guy.
06-01-2021 01:51 PM
MTLroadierunner
07-06-2015 12:17 PM
Steezy96yota
07-06-2015 10:00 AM
coryc85
07-06-2015 04:07 AM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1st Gen 4Runners: Low Fuel Light
