1st Gen 4runner rear 3 pt seat belts
Old 06-17-2010, 08:41 AM
yogmuney's Avatar
Hi all. I was looking forever to find a good solution for rear shoulder belts for my 89 4runner. This may have been posted before, but this is what I found. I was at the wrecking yard and pulled some front belts out of an 88 single cab truck. They come with plastic covers on the belt housing and bolt directly to the roll bar. There is even a stud that matches the hole just above the bolt hole in the roll bar. This may or may not be exactly what the optional rear belts were for the 4runner, but they were a direct bolt in with no mods necessary and look great. Hope this helps anyone looking for a similar solution.
Old 06-17-2010, 09:32 AM
kiyobrown's Avatar
Looks good dude.
You sell your wife on that soft top yet?
Old 05-23-2011, 04:56 PM
ToyoTech559's Avatar
for later use
Old 05-25-2011, 05:37 PM
Nervo19's Avatar
I did the same thing but with '93 truck belts into an '89 4Runner. The female part in the '89 was a different size so make sure you get both pieces if you go with different generations.
Old 05-25-2011, 05:38 PM
im looking to get the ones with the covers, i know only certain trim or body style had covers. oh and gray if possible
Old 04-05-2012, 02:21 PM
RAD4Runner's Avatar
Sweet! Thanks for the tip on the seatbelts!
-RAD
Old 04-05-2012, 04:01 PM
angrybob's Avatar
I too did this mod with the same front belts. A good piece of info to know is that the 11mm bolt that threads into the roll bar (and is pretty hard to find) is the same thread/pitch/diameter as a 7/16" UNF bolt.
Worked like a dream and readily available.
Old 04-05-2012, 04:15 PM
waskillywabbit's Avatar
It is actually a 7/16-20 bolt.
:wabbit2:
Old 04-05-2012, 04:46 PM
Junkers88's Avatar
Did the same thing in my 89.
Old 04-05-2012, 07:43 PM
corich's Avatar
Thanks for posting this - I was just on the phone with the local junkyard looking for rear shoulder belts for my '87 today, so this couldn't come at a better time.
Old 04-05-2012, 08:37 PM
BigBluePile's Avatar
Man I need to do that!
Old 04-06-2012, 01:58 AM
92 TOY's Avatar
this will probably be our next mod.
Alex's 4runner can live on forever!!
Old 04-06-2012, 04:50 AM
JoeT's Avatar
Excellent idea! Thanks for the post.
Old 07-25-2012, 03:48 AM
92 TOY's Avatar
:wabbit2:
boom
cuz i'm feeling like doing this. thanks me for using the search feature.
and den.... https://www.yotatech.com/forums/f116...t-size-194115/
but...how long?
Old 07-25-2012, 05:23 AM
92 TOY's Avatar
aaaaand...just got done upgrading BOTH rear belts. easy peezy.
Old 07-26-2012, 08:40 AM
92 TOY's Avatar
and took the 2 pockets that also came with them, cleaned them, plastic primered them and painted them.
Old 07-26-2012, 08:47 AM
Greg_Canada's Avatar
Awesome, i need to do this.
Old 07-26-2012, 10:25 AM
Philbert's Avatar
That looks great!
Old 07-26-2012, 12:27 PM
JAvendan's Avatar
nice!
my rear seat belts are not covered and your install look great.
joel
Old 07-29-2012, 10:41 PM
stanz's Avatar
Originally Posted by kiyobrown
Looks good dude.
I did this same swap in my 86 4Runner. I had an upholstery shop cut 6 inches off them and restitch them because they wouldn't fully retract (too long). Work perfectly.
Quick Reply: 1st Gen 4runner rear 3 pt seat belts
