1st gen 4runner Amber dash bulb swap (with pics) - $10 mod!
well 168's are stock, so obviously those would be preferred, but I'm not sure if they're as easily gotten as the 194's in amber, or any other colors for that matter
yeah turning the brightness down would be just as good to keep them running cooler
LED's would work good for brightness, low power, and NO heat from them. But do some research, and you'll quickly find mixed results on them. A lot of the times after installing LED's, people have the problem where the light is "blotchy", since most LED's are focused bulbs, meaning the shine 90% of their light straight forward from the bulb; the light from them doesn't fill the entire gauge cluster; there's light and dark spots all over the gauge faces. BUT, if the right LED's are used, that have the right bulb setup, I hear they can look better than stock
Did mine tonight...thanks for the inspiration! On my '90 SR5 there's a couple of the really small bulbs used for illumination too...I couldn't find any in amber, so I took off the little green condoms and got creative with an orange magic marker. Holding up so far, we'll see long-term how it does. Hey, if the marker thing works this could turn it into a $1 mod!
I was talking to a dude at the parts store, and he mentioned that he'd used model paint for his bulbs (as in the stuff you paint model cars with). Apparently, it's fairly heat-tolerant and works well...I'll give it a whirl if the marker fails.
I'll try to shoot a pic tomorrow, so far I'm really digging the new look.
#25
A NOTE ABOUT LEDs:
normal leds are cold when lit. they draw very little current and can be bright. ideal for this application
high power leds are hot when lit. some even burn hotter than a larger incandescent bulb, while producing more light. most require some sort of constant current driver to operate effectively. they are easily identified due to their wattage rating, which normal leds lack
also, just a heads up: make sure of [+] polarity [-] before reinstalling the entire dash (experience means doing it wrong at least once. i am experienced )
my 2¢
edit: also, a cheap way to diffuse spotty leds is to use some hot glue. just smear it over the lens. or, scuff it with some sandpaper or scotch-brite. both methods have worked well for me
now i'm up to 3¢
my 2¢
now i'm up to 3¢
#26
......SOooo. the stock dash lights are INCANDESANT 168's??? and the 194 LED's will fit the socket in the stock dash?? Which length 194 LED (out of the just shy of a million autoillumination offers) will fit without being too long?? I didn't miss that one did I? Which style 194 LED is everyone using I guess is what I'm asking....? (it's late here lol)
#27
first off, haha- that was post #168 for you. like the bulb number, get it..... (crickets)
anyway
i don't think anyone here has used (or posted what they use) led bulb replacements. i took my dash apart and it looks like there's plenty of room for their biggest "bulb"
anyway
#28
Curious what the brightest, widest spectrum bulb for my Dome would be, still???? lol. Don't mean to highjack... just thought someone was going to throw that out on here... NO? lol.
YES, Heli... DANG that Autoilluminati Co. has lots of bulbs, hahah. I kept scrolling and scrolling.... GEESH! lol. They supposedly have several kit's or bulbs that ONLY THEY make, ....from what I've read. Looking forward to getting a BRIGHT Dome!
#29
although I used some cheap green LED's off eBay... they were crap... not bright at all... and the low power consumption of the LED's made the dimmer not function like it should; they were either on or off
#30
if anyone is willing to go the diy route for extreme brightness:
the cree xp-g is one of the brightest and smallest led boards around, with a huge viewing angle (not spotty)
the led can be driven up to 1 amp by a steady on or dim-able (by external potentiometer) driver. oh, and these are all high power, so heat sinking is required. but there's enough light there to blind you from a few dozen feet away. i might be doing something like this for tail lights and turn signals, etc.
the site also has an assortment of 5mm leds which might be better for use in a dash. but you can still use the same dim-able driver to run them
i think i'm up to $0.04 now
#31
My contribution to the post would be that my 1986 non SR5 cluster takes only two bulbs. Also, the stock bulbs said 158 on them. Thanks for the idea. The yellow matches the rest of the lights in the truck. Why they used green is beyond me.
#33
Dash looks good Phil, not a big fan of the orange, though. I'd probably have gone with clear. Whatever you like, though, man. Thanks for the write-up!
#34
#35
Ran across this thread right before I was going to buy led's. Glad I did.
Ran up to Autozone and grabbed some bulbs. Amber of course to go with
my color. Now I have to wait for it to get dark!!! GRRRRRR!
Easy 5 min swap. Thanks mang!
#37
My bulbs said 168 or something not 194.....funny thing is they were out of amber 194's.....I brought a light socket with me to test fit bulbs just in case...
Still not dark enough for a pic yet. I did the jacket trick...meh...better than nothing....but not the orange coolness that only night can bring.....lol.
We will see if they are bright enough....I dont really want super freaking bright...prolly hurt my eyes.....
I dont even know what else lights up at night....but when it gets dark...Im sure ill know...lol. Then Ill go get some more bulbs.
#39
I love amber dash bulbs. My '89 Peugeot has them. Can these bulbs (the 168's) be had at an O'Reilly or such?
Edit: I see you (HiLux) went to AutoZone.
