1st gen 4runner-access to heater fan switch
Old 12-27-2011, 01:37 PM
stanz's Avatar
I'm finally getting my 4runner back tonight after two weeks at the mechanic. I want to replace the heater fan switch but am unclear on how the dash disassembles there. I know how the radio trim removes but know I need to go farther.
Can someone tell me how to get to it? Any pics would be a huge help too!
Old 12-27-2011, 05:52 PM
TinMan's Avatar
If your fan works on high and nothing else, it's not the switch, it's the blower motor resistor.
Old 12-27-2011, 06:34 PM
stanz's Avatar
Thanks! I've already replaced the resistor and the fan. Even had a mechanic replace the heater core and evaporator. While they had the dash apart I took all of the duct work and the box and resealed all of the flapper doors.
I have heat but I'm barely getting any airflow out the vents on all four fan speeds. I'm thinking the fan's not getting enough current. I don't know what else there is left to do.
Old 12-27-2011, 07:06 PM
Outsane's Avatar
have you checked the blower motor?
Old 12-27-2011, 07:11 PM
matstaley's Avatar
Pull the knobs off and then gently pry the face off of the controls. The rest is gravy.
Old 12-27-2011, 07:27 PM
TinMan's Avatar
That's interesting. If your getting limited air flow on all settings I would say to check all the wiring going to the motor. And then check the motor.
Old 12-27-2011, 11:33 PM
stanz's Avatar
Thanks for all of your help. Problem resolved! Once I pried the heater face off I was able to snake the switch back through the glove box opening and swap it out. The switch I cleaned up definitely had more juice. Additionally, I found out that the heater fan was wired in reverse. Once I fixed that I had dust blowing out all of the vents.
Thanks again!
the1998sr5
15
07-14-2020 08:35 PM
coryc85
09-09-2015 06:24 AM
jjrbus
07-19-2015 02:06 PM
noahstancik
07-17-2015 05:38 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: 1st gen 4runner-access to heater fan switch
